Visitor frankzhao92
xfopencv make error using 2018.2 SDK
I am having trouble compiling xfopencv examples using SDK (SDSoC) 2018.2 on ubuntu 14.04 machine. Here are the errors I get when I run make:
aarch64-linux-gnu-g++ -E -I. -I/usr/include -I../../include -O0 -Wall -DHLS_NO_XIL_FPO_LIB -mstrict-align -D __SDSCC__ -I /opt/Xilinx/SDx/2018.2/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I /opt/Xilinx/Vivado/2018.2/include /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_image_accel.cpp -o /home/sftdev/xfopencv/examples/accumulate/_sds/.pp/xf_accumulate_image_accel.iix
In file included from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/cstdlib:75:0,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/ext/string_conversions.h:41,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/basic_string.h:6349,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/string:52,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/locale_classes.h:40,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/bits/ios_base.h:41,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/ios:42,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/ostream:38,
from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/iostream:39,
from /opt/Xilinx/Vivado/2018.2/include/hls_stream.h:80,
from /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_config.h:34,
from /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_image_accel.cpp:31:
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/stdlib.h:131:36: error: missing binary operator before token "("
#if __HAVE_FLOAT128 && __GLIBC_USE (IEC_60559_TYPES_EXT)
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/stdlib.h:174:17: error: missing binary operator before token "("
#if __GLIBC_USE (IEC_60559_BFP_EXT)
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/stdlib.h:188:36: error: missing binary operator before token "("
In file included from /opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/include/c++/7.2.1/cmath:45:0,
from /opt/Xilinx/Vivado/2018.2/include/hls_half.h:32,
from /opt/Xilinx/Vivado/2018.2/include/ap_int_sim.h:73,
from /opt/Xilinx/Vivado/2018.2/include/ap_int.h:65,
from /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_config.h:35,
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:44:36: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:59:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:67:36: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:137:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:169:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:488:17: error: missing binary operator before token "("
/opt/Xilinx/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/aarch64-linux-gnu/libc/usr/include/math.h:835:17: error: missing binary operator before token "("
ERROR: [SdsCompiler 83-5019] Exiting sds++ : Error when calling 'aarch64-linux-gnu-g++ -E -I. -I/usr/include -I../../include -O0 -Wall -DHLS_NO_XIL_FPO_LIB -mstrict-align -D __SDSCC__ -I /opt/Xilinx/SDx/2018.2/target/aarch64-linux/include -D HLS_NO_XIL_FPO_LIB -I /opt/Xilinx/Vivado/2018.2/include /home/sftdev/xfopencv/examples/accumulate/xf_accumulate_image_accel.cpp -o /home/sftdev/xfopencv/examples/accumulate/_sds/.pp/xf_accumulate_image_accel.iix'
sds++ log file saved as /home/sftdev/xfopencv/examples/accumulate/_sds/reports/sds_xf_accumulate_image_accel.log
ERROR: [SdsCompiler 83-5004] Build failed
If I use 2017.4 SDK (SDSoC) on the same build machine, the xfopencv examples compiles successfully. Also to note, the hardware synthesis and build works on both 2017.4 and 2018.2, only software cannot compile.
Thanks in advance.
Re: xfopencv make error using 2018.2 SDK
Hi frankzhao92,
Looking at the log file, I am noticing that one of the include paths is point to your computer's include directory. Looking into your provided log files and matching it with the proper command in the Makefile, it looks like you're missing your SYSROOT path.
For the reVISION platform you would want to set an environment variable of SYSROOT to the sysroot directory to the specified platform (ZCU102 or ZCU104). This would be located in the zcu102_rv_ss/sw/sysroot location.
You can find more info here: https://github.com/Xilinx/Revision-Getting-Started-Guide/blob/master/tool-flow-tutorials.md
Steve
Hi frankzhao92,
Steve
Visitor frankzhao92
Using the correct SYSPATH value fixed this problem. Thanks Steve!
