取消
显示结果
搜索替代
您的意思是:
Visitor dengdengma
181 次查看
注册日期: ‎01-08-2019
在SDAccel中运行代码实例(该实例的host与kernel都是由HLS C写的)
在一个函数中用stream声明该函数参数列表中的几个参数,如图所示:
之后在对这个函数的调用过程中,声明几个stream类型的变量,带入到函数中:
之后在command line输入 make all TARGETS=hw_emu DEVICES=XXXX 时,报出如下问题:
请问,可能是什么原因呢?
0 项奖励
3 条回复3
167 次查看
注册日期: ‎07-16-2008
回复: 在SDAccel中运行代码实例(该实例的host与kernel都是由HLS C写的)
以下摘自UG902文档:
IMPORTANT: Ensure hls::stream variables are correctly sized when used in the default non-DATAFLOW regions.
If an hls::stream is used to transfer data between tasks (sub-functions or loops), you should immediately consider implementing the tasks in a DATAFLOW region where data streams from one task to the next. The default (non-DATAFLOW) behavior is to complete each task before starting the next task, in which case the FIFOs used to implement the hls::stream variables must be sized to ensure they are large enough to hold all the data samples generated by the producer task. Failure to increase the size of the hls::stream variables results in the error below:
ERROR: [XFORM 203-733] An internal stream xxxx.xxxx.V.user.V' with default size is used in a non-dataflow region, which may result in deadlock. Please consider to resize the stream using the directive 'set_directive_stream' or the 'HLS stream' pragma.
This error informs you that in a non-DATAFLOW region (the default FIFOs of depth of 1) may not be large enough to hold all the data samples written to the FIFO by the producer task.
0 项奖励
Visitor dengdengma
120 次查看
注册日期: ‎01-08-2019
非常谢谢!
0 项奖励
Visitor dengdengma
118 次查看
注册日期: ‎01-08-2019
上次修改之后,程序的sw_emu和hw_emu都可以通过。
但是在输入make check TARGETS=hw DEVICES=xxxx时,也就是要上板的时候,一直卡在Executing OpenCL Kernel这不动,请问可能是什么原因呢?
0 项奖励
