取消
显示结果
搜索替代
您的意思是:
Visitor willyeyem5
239 次查看
注册日期: ‎12-18-2018
SDAccel 編譯錯誤, 為何?
Hi 您好 :
我使用 xilinx 提供的 example project,
但編譯不過,
請問這是何原因呢 ?
(1) host.cpp :
Copyright (c) 2018, Xilinx, Inc.
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
2. Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
3. Neither the name of the copyright holder nor the names of its contributors
may be used to endorse or promote products derived from this software
without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* Changes from Lab 0:
Added new file mmult.cl with function implementation in OpenCL form. The function has
OpenCL specific attibutes and added __global identifier on arguments.
In host.cpp, added a new function called mmult_fpga(). Inside this function, added
code to setup OpenCL context and command queue, import the xclbin binary to create
cl::Program, create cl::Kernel with the program, create cl::Buffers and copy them
to/from device/host, then set kernel args and trigger the kernel using enqueueTask()
function.
//OpenCL utility layer include
#include "xcl2.hpp"
#include <stdlib.h>
#include <vector>
//Array Size to access
#define DATA_SIZE 64
uint64_t get_duration_ns (const cl::Event &event) {
uint64_t nstimestart, nstimeend;
event.getProfilingInfo<uint64_t>(CL_PROFILING_COMMAND_START,&nstimestart);
event.getProfilingInfo<uint64_t>(CL_PROFILING_COMMAND_END,&nstimeend);
return(nstimeend-nstimestart);
//CPU implementation of Matrix Multiplication
//The inputs are of the size (DATA_SIZE x DATA_SIZE)
void mmult_cpu (
int *in1, //Input Matrix 1
int *in2, //Input Matrix 1
int *out, //Input Matrix 1
int dim //One dimension of matrix
//Performs Matrix multiply Out = In1 x In2
for(int i = 0; i < dim; i++) {
for(int j = 0; j < dim; j++) {
for(int k = 0; k < dim; k++) {
out[i * dim + j] += in1[i * dim + k] * in2[k * dim + j];
//Functionality to setup OpenCL context and trigger the Kernel
uint64_t mmult_fpga (
std::vector<int,aligned_allocator<int>>& source_in1, //Input Matrix 1
std::vector<int,aligned_allocator<int>>& source_in2, //Input Matrix 2
std::vector<int,aligned_allocator<int>>& source_fpga_results, //Output Matrix
int size = dim;
size_t matrix_size_bytes = sizeof(int) * size * size;
//The get_xil_devices will return vector of Xilinx Devices
std::vector<cl::Device> devices = xcl::get_xil_devices();
cl::Device device = devices[0];
//Creating Context and Command Queue for selected Device
cl::Context context(device);
cl::CommandQueue q(context, device, CL_QUEUE_PROFILING_ENABLE);
std::string device_name = device.getInfo<CL_DEVICE_NAME>();
//import_binary() command will find the OpenCL binary file created using the
//xocc compiler load into OpenCL Binary and return as Binaries
//OpenCL and it can contain many functions which can be executed on the
//device.
std::string binaryFile = xcl::find_binary_file(device_name,"mmult");
cl::Program::Binaries bins = xcl::import_binary_file(binaryFile);
devices.resize(1);
cl::Program program(context, devices, bins);
//This call will extract a kernel out of the program we loaded in the
//previous line. A kernel is an OpenCL function that is executed on the
//FPGA. This function is defined in the src/mmult.cl file.
cl::Kernel kernel(program,"mmult");
//These commands will allocate memory on the FPGA. The cl::Buffer
//objects can be used to reference the memory locations on the device.
//The cl::Buffer object cannot be referenced directly and must be passed
//to other OpenCL functions.
cl::Buffer buffer_in1(context,CL_MEM_USE_HOST_PTR | CL_MEM_READ_ONLY,
matrix_size_bytes,source_in1.data());
cl::Buffer buffer_in2(context,CL_MEM_USE_HOST_PTR | CL_MEM_READ_ONLY,
matrix_size_bytes,source_in2.data());
cl::Buffer buffer_output(context,CL_MEM_USE_HOST_PTR | CL_MEM_WRITE_ONLY,
matrix_size_bytes,source_fpga_results.data());
//These commands will load the source_in1 and source_in2 vectors from the host
//application into the buffer_in1 and buffer_in2 cl::Buffer objects. The data
//will be be transferred from system memory over PCIe to the FPGA on-board
//DDR memory.
q.enqueueMigrateMemObjects({buffer_in1, buffer_in2},0/* 0 means from host*/);
//Set the kernel arguments
int narg = 0;
kernel.setArg(narg++, buffer_in1);
kernel.setArg(narg++, buffer_in2);
kernel.setArg(narg++, buffer_output);
kernel.setArg(narg++, size);
cl::Event event;
uint64_t kernel_duration = 0;
//Launch the kernel
q.enqueueTask(kernel, NULL, &event);
//The result of the previous kernel execution will need to be retrieved in
//order to view the results. This call will write the data from the
//buffer_output cl_mem object to the source_fpga_results vector
q.enqueueMigrateMemObjects({buffer_output},CL_MIGRATE_MEM_OBJECT_HOST);
q.finish();
kernel_duration = get_duration_ns(event);
return kernel_duration;
int main(int argc, char** argv)
//Allocate Memory in Host Memory
int size = DATA_SIZE;
//When creating a buffer with user pointer, under the hood user ptr is
//used if and only if it is properly aligned (page aligned). When not
//aligned, runtime has no choice but to create its own host side buffer
//that backs user ptr. This in turn implies that all operations that move
//data to/from device incur an extra memcpy to move data to/from runtime's
//own host buffer from/to user pointer. So it is recommended to use this
//allocator if user wish to Create Buffer/Memory Object to align user buffer
//to the page boundary. It will ensure that user buffer will be used when
//user create Buffer/Mem Object.
std::vector<int,aligned_allocator<int>> source_in1(matrix_size_bytes);
std::vector<int,aligned_allocator<int>> source_in2(matrix_size_bytes);
std::vector<int,aligned_allocator<int>> source_fpga_results(matrix_size_bytes);
std::vector<int,aligned_allocator<int>> source_cpu_results(matrix_size_bytes);
//Create the test data
for(int i = 0 ; i < DATA_SIZE * DATA_SIZE ; i++){
source_in1[i] = rand() % size;
source_in2[i] = rand() % size;
source_cpu_results[i] = 0;
source_fpga_results[i] = 0;
//Compute CPU Results
mmult_cpu(source_in1.data(), source_in2.data(), source_cpu_results.data(), size);
//Compute FPGA Results
kernel_duration = mmult_fpga(source_in1, source_in2, source_fpga_results, size);
//Compare the results of FPGA to CPU
bool match = true;
for (int i = 0 ; i < size * size; i++){
if (source_fpga_results[i] != source_cpu_results[i]){
std::cout << "Error: Result mismatch" << std::endl;
std::cout << "i = " << i << " CPU result = " << source_cpu_results[i]
<< " FPGA result = " << source_fpga_results[i] << std::endl;
match = false;
break;
std::cout << "TEST " << (match ? "PASSED" : "FAILED") << std::endl;
std::cout << "Wall Clock Time (Kernel execution): " << kernel_duration << std::endl;
std::cout << "Note: Wall Clock Time is meaningful for real hardware execution only,"
<< "not for emulation." << std::endl;
return (match ? EXIT_SUCCESS : EXIT_FAILURE);
(2) mmult.cl :
// This function represents an OpenCL kernel. The kernel will be call from
// host application using the xcl_run_kernels call. The pointers in kernel
// parameters with the global keyword represents cl_mem objects on the FPGA
// DDR memory.
#define BUFFER_SIZE 256
kernel __attribute__((reqd_work_group_size(1, 1, 1)))
void vector_add(global int* c,
global const int* a,
global const int* b,
const int n_elements)
int arrayA[BUFFER_SIZE];
int arrayB[BUFFER_SIZE];
for (int i = 0 ; i < n_elements ; i += BUFFER_SIZE)
int size = BUFFER_SIZE;
if (i + size > n_elements) size = n_elements - i;
readA: for (int j = 0 ; j < size ; j++) arrayA[j] = a[i+j];
readB: for (int j = 0 ; j < size ; j++) arrayB[j] = b[i+j];
vadd_writeC: for (int j = 0 ; j < size ; j++) c[i+j] = arrayA[j] + arrayB[j];
Error 錯誤請見夾檔, thanks.
0 项奖励
1 条回复1
216 次查看
注册日期: ‎05-23-2018
回复: SDAccel 編譯錯誤, 為何?
Hi, @willyeyem5
可以贴出报错信息的log file吗?
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
