取消
显示结果
搜索替代
您的意思是:
339 次查看
注册日期: ‎05-24-2017
how to caculate the number of DSP slices used by the kernel.
I am trying to synthesis the following code block.
The CHANNEL_WID*NUM_D_PER_512 in line132 is eual 32.
So the for loop (line 132) is completely unrolled .
The final result is this block consume 128 DSP slices.
I know the multiplifier in the line 34 will consume some DSP.
Since the DSP48E2 supports  27 x 18 bit operands , so two DSP slices are needed for the 32 bit x 32 bit case.
If so only 32*2=64 DSP slices are needed.
Wy the final result is 128 DSP slices?
Does the red operators in the line 132 and 133 also cost DSP slices?
Please correct me if I am wrong.
  #define BITWIDTH 32
30 #define CHANNEL_WID 2 //hls::stream width
31 #define NUM_D_PER_512 16 //number of data per read
32 #define NUM_R_PER_SAM 60 //number read per sample
41 typedef ap_int<BITWIDTH> feature_T;
42 typedef ap_int<BITWIDTH_OUT> feature_T_B;
43 typedef int Dtype_uint;
44 typedef int Dtype_H2Ki;//
dist_calc_or0: for(Dtype_uint i=0; i < data_size*NUM_R_PER_SAM/CHANNEL_WID; i++){ 129 #pragma HLS PIPELINE 130 feature_or = feature_or_in.read(); 131 132 for(int k=0; k<CHANNEL_WID*NUM_D_PER_512;k++){ 133 Dtype_l tmp=feature_or.x[k]-query_or->x[i%(NUM_R_PER_SAM/CHANNEL_WID)*CHANNEL_WID*NUM_D_PER_512+k]; 134 dist_temp.x[k]= tmp*tmp; 135 } 136 dist_temp_buffer << dist_temp; 139 } 140 }
0 项奖励
3 条回复3
Teacher xilinxacct
324 次查看
注册日期: ‎10-24-2018
回复: how to caculate the number of DSP slices used by the kernel.
@mathmaxsean
Can you provide a little more detail?
What are the datatypes?
Are all the named items contants or #define? If so, what are the values?
0 项奖励
296 次查看
注册日期: ‎05-24-2017
@xilinxacct
Thanks for reminding me.
I update the the message.
0 项奖励
Teacher xilinxacct
288 次查看
注册日期: ‎10-24-2018
@mathmaxsean
Still under specified... BITWIDTH_OUT, data_size, feature_or_in, Dtype_l, query_or ...
0 项奖励
