取消
显示结果
搜索替代
您的意思是:
Observer zhengjia
230 次查看
注册日期: ‎07-24-2018
sdsoc 添加hls头文件是报错
转到解答
参考https://forums.xilinx.com/t5/SDSoC-Environment-and-reVISION/hls-CvtColor-amp-xf-Threshold/m-p/899203#M2985 这篇文章写的sdsoc + hls::stream
接口函数的程序,已经设置了正确的SYSROOT路径,编译时会出现如下的错误,但是编译xf opencv的例子是正确的,
错误如下:请问如何解决,版本是sdx2018.2 revision平台
15:13:30 **** Incremental Build of configuration Release for project hars ****
make pre-build main-build
sdsoc_make_clean Release
Building file: ../src/top.cpp
Invoking: SDS++ Compiler
sds++ -DHLS_NO_XIL_FPO_LIB -Wall -O3 -I"../src" -I/home/zhengjia/SDSoc/platform/zcu102_rv_1802/zcu102_rv_ss/sw/a53_linux/a53_linux/inc/xfopencv -c -fmessage-length=0 -MT"src/top.o" -I/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include/c++/6.2.1 -I/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include/c++/6.2.1/aarch64-xilinx-linux -I/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include/c++/6.2.1/backward -I/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include -I/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include/glib-2.0 -I/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/lib/glib-2.0/include -I/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1 -I/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/aarch64-linux-gnu -I/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include/c++/6.2.1/backward -I/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include -I/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/lib/gcc/aarch64-linux-gnu/6.2.1/include-fixed -I/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/nt/aarch64-linux/aarch64-linux-gnu/include -Wno-overloaded-virtual -Wno-unused-label -Wno-strict-overflow -Wno-uninitialized -Wno-unused-function -Wno-unused-variable -Wno-unknown-attributes -Wno-unused-local-typedefs -Wno-sign-compare -mstrict-align -hls-target 1 -MMD -MP -MF"src/top.d" -MT"src/top.o" -o "src/top.o" "../src/top.cpp" -sds-hw integralimagehls top.cpp -clkid 2 -sds-end -sds-sys-config a53_linux -sds-proc a53_linux -sds-pf "/home/zhengjia/SDSoc/platform/zcu102_rv_1802/zcu102_rv_ss"
Processing -sds-hw block for integralimagehls
Create data motion intermediate representation
/home/tools/SDx2018.2/Vivado/2018.2/include/ap_int_special.h:99:1: warning: 'complex' defined as a struct template here but previously declared as a class template [-Wmismatched-tags]
struct complex<ap_int<_AP_W> > {
/home/tools/SDx2018.2/Vivado/2018.2/include/ap_int_special.h:71:24: note: did you mean struct here?
template<typename _Tp> class complex;
struct
/home/tools/SDx2018.2/Vivado/2018.2/include/ap_fixed_special.h:99:1: warning: 'complex' defined as a struct template here but previously declared as a class template [-Wmismatched-tags]
struct complex<ap_fixed<_AP_W, _AP_I, _AP_Q, _AP_O, _AP_N> > {
/home/tools/SDx2018.2/Vivado/2018.2/include/ap_fixed_special.h:71:24: note: did you mean struct here?
struct
struct
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:30:13: warning: unknown pragma ignored [-Wunknown-pragmas]
#pragma GCC push_options
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:31:13: warning: unknown pragma ignored [-Wunknown-pragmas]
#pragma GCC target ("+nothing+simd")
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:38:9: error: unknown type name '__Int8x8_t'
typedef __Int8x8_t int8x8_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:39:9: error: unknown type name '__Int16x4_t'
typedef __Int16x4_t int16x4_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:40:9: error: unknown type name '__Int32x2_t'; did you mean '__int32_t'?
typedef __Int32x2_t int32x2_t;
__int32_t
/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include/bits/types.h:40:20: note: '__int32_t' declared here
typedef signed int __int32_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:41:9: error: unknown type name '__Int64x1_t'; did you mean '__int64_t'?
typedef __Int64x1_t int64x1_t;
__int64_t
/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include/bits/types.h:43:25: note: '__int64_t' declared here
typedef signed long int __int64_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:42:9: error: unknown type name '__Float16x4_t'
typedef __Float16x4_t float16x4_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:43:9: error: unknown type name '__Float32x2_t'
typedef __Float32x2_t float32x2_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:44:9: error: unknown type name '__Poly8x8_t'
typedef __Poly8x8_t poly8x8_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:45:9: error: unknown type name '__Poly16x4_t'
typedef __Poly16x4_t poly16x4_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:46:9: error: unknown type name '__Uint8x8_t'
typedef __Uint8x8_t uint8x8_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:47:9: error: unknown type name '__Uint16x4_t'
typedef __Uint16x4_t uint16x4_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:48:9: error: unknown type name '__Uint32x2_t'
typedef __Uint32x2_t uint32x2_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:49:9: error: unknown type name '__Float64x1_t'
typedef __Float64x1_t float64x1_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:50:9: error: unknown type name '__Uint64x1_t'
typedef __Uint64x1_t uint64x1_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:51:9: error: unknown type name '__Int8x16_t'; did you mean '__int16_t'?
typedef __Int8x16_t int8x16_t;
__int16_t
/home/zhengjia/SDSoc/platform/zcu102_rv_1802/sysroot//usr/include/bits/types.h:38:26: note: '__int16_t' declared here
typedef signed short int __int16_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:52:9: error: unknown type name '__Int16x8_t'
typedef __Int16x8_t int16x8_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:53:9: error: unknown type name '__Int32x4_t'; did you mean '__int32_t'?
typedef __Int32x4_t int32x4_t;
__int32_t
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:54:9: error: unknown type name '__Int64x2_t'; did you mean '__int64_t'?
typedef __Int64x2_t int64x2_t;
__int64_t
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:55:9: error: unknown type name '__Float16x8_t'
typedef __Float16x8_t float16x8_t;
/home/tools/SDx2018.2/SDK/2018.2/gnu/aarch64/lin/aarch64-linux/lib/gcc/aarch64-linux-gnu/7.2.1/include/arm_neon.h:56:9: error: unknown type name '__Float32x4_t'
typedef __Float32x4_t float32x4_t;
fatal error: too many errors emitted, stopping now [-ferror-limit=]
ERROR: [SdsCompiler 83-5005] clang exited with non-zero code processing /home/zhengjia/SDSoc/sdsoc182/sdx_gui/hars/hars/src/top.cpp
sds++ log file saved as /home/zhengjia/SDSoc/sdsoc182/sdx_gui/hars/hars/Release/_sds/reports/sds_top.log
ERROR: [SdsCompiler 83-5004] Build failed
make: *** [src/top.o] Error 1
15:13:37 Build Finished (took 7s.349ms)
补充下,我已经加了下面语句了
#if __SDSCC__
#undef __ARM_NEON__
#undef __ARM_NEON
#include "opencv2/opencv.hpp"
#include "opencv2/imgproc/imgproc.hpp"
#include "opencv2/highgui/highgui.hpp"
#define __ARM_NEON__
#define __ARM_NEON
#else
#endif
进一步测试发现只要添加如下两个头文件就会报错,难道是sdsoc不支持这两个头文件还是说应该特殊处理下
#include "hls_video.h"
#include "hls_opencv.h"
0 项奖励
1 个已接受解答
已接受的解答
195 次查看
注册日期: ‎05-27-2018
回复: sdsoc 添加hls头文件是报错
转到解答
Hi @zhengjia
     1、参考一下这个链接#include "hls_video.h" #include "hls_opencv.h" 这两个头文件,只支持仿真,不支持综合,所以综合会报错。关于如何综合实现参考一下 XAPP1167。
     2、关于你的log上显示的内容,HLS 不支持 #pragma GCC 这个指令所以有报错,以及看到一些data  type 的报错,参考UG902里面对于Vivado HLS
支持的任意精度数据类型的表述。或者   #include <ap_int.h> 查看一下头文件。
     另,如果还有其他问题方便把源文件以附件形式帖一下吗?
谢谢,
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
0 项奖励
4 条回复
196 次查看
注册日期: ‎05-27-2018
转到解答
Hi @zhengjia
谢谢,
Wen
0 项奖励
Observer zhengjia
190 次查看
注册日期: ‎07-24-2018
转到解答
好的,谢谢,明白了
如果我想用resize api,由于xf::resize只支持单通道,而hl::resize不被支持综合,如果想处理rgb 的resize功能,需要硬件加速,只能手写了吗?有没有其它替代方法
0 项奖励
175 次查看
注册日期: ‎05-27-2018
转到解答
Hi @zhengjia
    尝试将RGB的通道分开分别进行resize呢?
0 项奖励
Observer zhengjia
100 次查看
注册日期: ‎07-24-2018
转到解答
那样就慢了
0 项奖励
