legendbb
Voyager
Voyager
10G/25G subsystem, how to bring out gt_refclk?
I have a design with 10G/25G subsystem (including shared logic in core) in block design.
Is there a way to bring out gt_refclk to share with other Quads?
The port gt_reclk_out is after BUFGT_GT
Or maybe I have to change the core to "Include Shared Logic in example design" then add example design into block design. That complicates design hierarchy.
Please comment,
venkata
apologies. It is my mistake in reading your query.
For me, it seems you need to set "Shared logic in example", keep the IBUFDS_GTe4 and QPLL outside of the IPI design and bring in the shard logic ports to IPI design.
venkata
which vivado version are you using? In vivado 2017.4, I can see gt_refclk_out port at the IP interface.10g_25g.PNG
legendbb
Voyager
Voyager
I'm on 2017.3 can see gt_refclk_out too.
I assume gt_refclk_out after BUFG_GT can't be as reference clock source for other Quads,
Only gt_refclk can be used.
Following code is from example design without shared logic in core.
venkata
