Newbie maria_d
Aligned and unaligned word transfers on a 64-bit bus
Can you please explain this example of unaligned word transfer on 64 bit bus.
Why the second transfer started from 8 and not from C?
Re: Aligned and unaligned word transfers on a 64-bit bus
The transceiver needs help determining how the parallel to serial conversion frames the data.  Usually there is encoding defined on the protocol level to help determine where this alignment should be.  Usually you would be using either 64/66 encoding which has header bits to align with or 8B/10B encoding which has comma characters.  Are you using an encoding?  See the byte alignment section of UG476 or UG576 for a more detailed discussion.  I need to understand the timing of these bursts better.  Are you using a protocol?
Roy
