Analysis of IBERT eyescan results and ways to improve it
Hello all,
Am i right to say that a good eyescan result has a horizontal margin error of (+- 0.15 UI) and vertical margin error of (+- 30 voltage code) ?
I have done a copper link loopback on ZCU111 evaluation board using Samtec firefly. Below is my eyescan result of copper wire channel. My settings are indicated in the picture below. Anyways to improve my eyescan result ?
Re: Analysis of IBERT eyescan results and ways to improve it
Do a scan with 10^9 samples.  It looks like yours has more.  It is a close call on whether it is wide enough so use vertical and horizontal increments of 1.  You have the ability to change the emphasis and amplitude and it looks like you could move the signal back to the right by changing those settings.  Probably you just want to do a some sweeps to find the best set up. You should also see whether PMA equalization gives you a better result.  The equalization is auto adapting so there isn't anything else to adjust.
