ptaddoni
Aurora IP Core - Disable Clock Compensation Sequence
Hello.
I am wondering how to disable Clock Compensation in Aurora 64b66b when using recent versions with do_cc removed.
I have synchronous reference clocks, and I have disabled hot-plug.
I want to disable Clock Compensation because the gaps its creates in the received data are increasing my latency across the link.
-Paul
venkata
Are you using Aurora in Simplex mode?
.@.@.v.@.@.
Just to clarify, does the Aurora care in Simplex mode not do clock compensation?
