ldkazuma
Boosting GTH transceiver clock input
I am currently using a 100Mhz offboard reference clock for a 9.6Ghz and 10.4Ghz application. Currently using Zynq Ultrascale+ FPGA.
I've looked at the equations presented in Equation 2-3 and 2-4 in UG576. This is showing me that even if maximize N (to 160) and minimize M (to 1), I'm still only going up to an 8Ghz PLLClkout for a reference input clock of 100Mhz. And I can't set my PLLClkout any lower than 8Ghz because of the nominal frequency ranges in Table 2-12.
I was considering sending my 100Mhz clock into an MMCM and turning it into a 200Mhz clock before feeding it into the GTH Transceiver, but I'm not sure if this is a viable option. I'm also unsure what the global clocking resources would look like at that point. Not sure if there is a single-ended version of IBUFDS_GTE4.
Does anyone have any good ideas here?
borisq
hi @ldkazuma
I believe the line rate is 9.6Gbps and 10.4Gbps, right?
If so, just select the line rate and select 100Mhz refenrece clock. Please see the figure below.
Vivado will take care of the details in the background.
The reference clock has to be differential. MMCM cannot generate reference clock for GTs as it is noisy and link margin is limited.
Boris
borisq
hi @ldkazuma
Boris
karnanl
Hello @ldkazuma
I agree with Boris answer. @borisq
BTW, What is the problem you want to share with us, I do not understand.
With PLLClkout = 8GHz, you can achieve LineRate=16Gbps.
The value in this table is correct. You cannot operate QPLL lower than 8GHz.
But please notice that we can set the divider value (D) to achive lower line-rate.
( So if D=4, Line-rate is 2Gbps, if D=8 Line-rate is 1Gbps and so on ... )
As mentioned by Boris, this is not supported, and it will not work on HW.
You can use 100MHz REFCLK for 28Gbps line-rate, no need to use MMCM. See below.
Thanks & regards
Leo
Versal Blogs
ldkazuma
I wasn't aware there was a transceiver wizard until I dug deeper into the documentation. Thank you very much for the explanation everyone.
