Participant justinhk
CDR of Virtex Ultrascale GTY
What's the recommended CDR setting for PCIE gen2  on GTY (5Gb/s, +/-600ppm offset, -5000ppm to 0ppm SSC)?
I don't find preset setting in IP Wizard...
回复: CDR of Virtex Ultrascale GTY
hi @justinhk
pls check pg156 Clocking section.
https://www.xilinx.com/support/documentation/ip_documentation/pcie3_ultrascale/v4_4/pg156-ultrascale-pcie-gen3.pdf
the supported case is
+/-300 ppm (totally 600 ppm) + no_SSC
or
0 ppm + SSC
Below is the document.
Clocking
The UltraScale Devices Gen3 Integrated Block for PCIe core can be configured to use 100 MHz, 125 MHz, or 250 MHz reference clock. The following applies:
•The reference clock can be synchronous or asynchronous with up to ±300 PPM or 600 PPM worst case. (If spread spectrum clock (SSC) is enabled, the link must be synchronous.)
Boris
Re: CDR of Virtex Ultrascale GTY
Hello @justinhk
We do not recommend to use GTY standalone for PCIe protocol, this is why PCIe preset is not available in GTY GUI.
Please use PCIe GUI from Vivado to generate the PCIe IP ( with GTY inside the IP)
- If you are using Xilinx PCIe Hard-block please use (Ultrascale+ PCI Express Integrated Block 1.3) GUI,
  Please use PCIe GUI to generate PCIe IP with Gen2 configuration, and GTY will be generated with default/recommended CDR setting for Gen2.
- If you are using GTY as a PHY with 3rd party Link/Transcaction layer IP, Please generate GTY using (PCIe PHY IP) GUI.
Thanks & regards
Leo
I'm using GTY as a PHY (use PMA block).  I'm verifying my own PCS implemented in fabric logic.  What's the recommended way to generate the GTY IP?
Hello @justinhk
PCI Express PHY is a good place to start.
https://www.xilinx.com/support/documentation/ip_documentation/pcie_phy/v1_0/pg239-pcie-phy.pdf
Please read chapter 1 to check if your device is supported or not.
Hope this helps.
Leo
" While some UltraScale devices contain GTYs, this IP does not support GTY in the UltraScale family"
This is so frustrating.  I'm using VCU108 EVK.  Even though the products claimed the phy support PCIe gen2, it seems there is no way to configure the CDR for PCIE gen2  on GTY (5Gb/s, +/-600ppm offset, -5000ppm to 0ppm SSC).......
@deepeshm, @borisq
Do you have any input on this ?
Thanks & regards
Leo
hi @justinhk
or
0 ppm + SSC
Clocking
Boris
Hi @borisq @karnanl
Because preset is not availiable in GT wizard and the PCIe PHY Logicore also not support Ultrascale GTY.  So, how to set the GTY CDR in GT wizard or DRP to supppot PCIe Gen2 electrical signal?
hi @justinhk
if think you can generate PCIe Integrated Block IP for Ultrascale GTY, can copy the GTY wrappers to your project.
Here is an example reference for 7 series.
https://www.xilinx.com/support/answers/62530.html
Boris
