Can I enable/ disable the GTH 8b10b encoder on the run?
I know it's possible when configuring it, but I would like to have is a transceiver able to swap between scrambling and encoding on the go. I am aware this implies a data rate change as well.
Re: Can I enable/ disable the GTH 8b10b encoder on the run?
According to the GTH User Guide there are TX8B10BBYPASS and TX8B10BEN signals so I guess so.
hi,
you need a reset and the fabric should be able to switch between multiple of 8 and multiple of 10 bits data width. You can run a simulation:
1) drive the TX with a PRBS generator
2) when TX and RX 8B10B is present just look at RX disparity error and out of table
3) bypass the encoder/decoder, change bus width  ... prepare to read multiple of 10 bits at receiver side and bring them to a PRBS checker. apply a reset
You might create two Wizard example design cases, with and without 8B10B encoder: this will guide for clock frequencies and HSSIO setup (and in case of UltraScale device it will also give you a good example of parallel PRBS generator/checker)
