Change linerate GTH
I am planning a circuit-board with an ADC and an FPGA. The FPGA receives the captured date with a GHT-Transceiver. The samplerate of the ADC should be changeable and if the samplerate changes, the linerate of the GTH-Transceiver also changes. In my opinion I have to possibilities to manage that.
1. I change the refclk-frequency of the GTH-Transceiver
2. I change the PLL-divider settings
Which method would you prefer?
Do I have to reset the PLL and the Transceiver in both cases, or can I just change the refclk-frequency from external?
What is the possible refclk-frequency-range?
Thank you.
Markus
Re: Change linerate GTH
If you want to change the linerate in coarse steps, then look at RXRATE/TXRATE ports of GTH.
In previous FPGA families changing the linerate required resetting the GT, not sure if this still holds true for ultrascale.
hi Markus,
the line rate dynamically change is not simply changing the ref clock or divider.
because many things could change if the linerate varies.
below is an reference design for dynamically switch between 1G ethernet and 10G.
https://www.xilinx.com/support/documentation/application_notes/xapp1307-1g-10g-switching.pdf
you can take a look and start from there.
Boris
Unable to run 1g_10f reference design in vivado 2018.3, IP does not get updated during IP update process.
ERROR: [Synth 8-448] named port connection 'soft_reset_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:351]
ERROR: [Synth 8-448] named port connection 'gt0_cpllfbclklost_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:361]
ERROR: [Synth 8-448] named port connection 'gt0_cplllock_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:362]
ERROR: [Synth 8-448] named port connection 'gt0_cplllockdetclk_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:363]
ERROR: [Synth 8-448] named port connection 'gt0_cpllrefclklost_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:364]
ERROR: [Synth 8-448] named port connection 'gt0_cpllreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:365]
ERROR: [Synth 8-448] named port connection 'gt0_gtrefclk0_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:367]
ERROR: [Synth 8-448] named port connection 'gt0_drpaddr_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:369]
ERROR: [Synth 8-448] named port connection 'gt0_drpclk_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:370]
ERROR: [Synth 8-448] named port connection 'gt0_drpdi_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:371]
ERROR: [Synth 8-448] named port connection 'gt0_drpdo_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:372]
ERROR: [Synth 8-448] named port connection 'gt0_drpen_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:373]
ERROR: [Synth 8-448] named port connection 'gt0_drprdy_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:374]
ERROR: [Synth 8-448] named port connection 'gt0_drpwe_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:375]
ERROR: [Synth 8-448] named port connection 'gt0_dmonitorout_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:376]
ERROR: [Synth 8-448] named port connection 'gt0_loopback_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:378]
ERROR: [Synth 8-448] named port connection 'gt0_rxpd_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:380]
ERROR: [Synth 8-448] named port connection 'gt0_txpd_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:381]
ERROR: [Synth 8-448] named port connection 'gt0_eyescanreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:383]
ERROR: [Synth 8-448] named port connection 'gt0_rxuserrdy_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:384]
ERROR: [Synth 8-448] named port connection 'gt0_eyescandataerror_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:386]
ERROR: [Synth 8-448] named port connection 'gt0_eyescantrigger_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:387]
ERROR: [Synth 8-448] named port connection 'gt0_rxcdrlock_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:389]
ERROR: [Synth 8-448] named port connection 'gt0_rxusrclk_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:391]
ERROR: [Synth 8-448] named port connection 'gt0_rxusrclk2_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:392]
ERROR: [Synth 8-448] named port connection 'gt0_rxdata_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:394]
ERROR: [Synth 8-448] named port connection 'gt0_rxprbserr_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:396]
ERROR: [Synth 8-448] named port connection 'gt0_rxprbssel_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:397]
ERROR: [Synth 8-448] named port connection 'gt0_rxprbscntreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:399]
ERROR: [Synth 8-448] named port connection 'gt0_rxdisperr_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:401]
ERROR: [Synth 8-448] named port connection 'gt0_rxnotintable_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:402]
ERROR: [Synth 8-448] named port connection 'gt0_gttxreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:403]
ERROR: [Synth 8-448] named port connection 'gt0_gtrxreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:404]
ERROR: [Synth 8-448] named port connection 'gt0_gthrxn_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:406]
ERROR: [Synth 8-448] named port connection 'gt0_rxbufreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:408]
ERROR: [Synth 8-448] named port connection 'gt0_rxbufstatus_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:409]
ERROR: [Synth 8-448] named port connection 'gt0_rxbyteisaligned_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:411]
ERROR: [Synth 8-448] named port connection 'gt0_rxbyterealign_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:412]
ERROR: [Synth 8-448] named port connection 'gt0_rxcommadet_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:413]
ERROR: [Synth 8-448] named port connection 'gt0_rxmcommaalignen_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:414]
ERROR: [Synth 8-448] named port connection 'gt0_rxpcommaalignen_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:415]
ERROR: [Synth 8-448] named port connection 'gt0_rxdfeagchold_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:417]
ERROR: [Synth 8-448] named port connection 'gt0_rxdfeagcovrden_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:418]
ERROR: [Synth 8-448] named port connection 'gt0_rxdfelfhold_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:419]
ERROR: [Synth 8-448] named port connection 'gt0_rxdfelpmreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:420]
ERROR: [Synth 8-448] named port connection 'gt0_rxmonitorout_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:421]
ERROR: [Synth 8-448] named port connection 'gt0_rxmonitorsel_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:422]
ERROR: [Synth 8-448] named port connection 'gt0_rxoutclk_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:424]
ERROR: [Synth 8-448] named port connection 'gt0_rxpcsreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:426]
ERROR: [Synth 8-448] named port connection 'gt0_rxpmareset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:427]
ERROR: [Synth 8-448] named port connection 'gt0_rxlpmen_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:429]
ERROR: [Synth 8-448] named port connection 'gt0_rxpolarity_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:431]
ERROR: [Synth 8-448] named port connection 'gt0_rxchariscomma_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:433]
ERROR: [Synth 8-448] named port connection 'gt0_rxcharisk_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:434]
ERROR: [Synth 8-448] named port connection 'gt0_gthrxp_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:436]
ERROR: [Synth 8-448] named port connection 'gt0_rxresetdone_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:438]
ERROR: [Synth 8-448] named port connection 'gt0_rxpmaresetdone_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:439]
ERROR: [Synth 8-448] named port connection 'gt0_txpostcursor_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:441]
ERROR: [Synth 8-448] named port connection 'gt0_txprecursor_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:442]
ERROR: [Synth 8-448] named port connection 'gt0_txuserrdy_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:444]
ERROR: [Synth 8-448] named port connection 'gt0_txchardispmode_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:446]
ERROR: [Synth 8-448] named port connection 'gt0_txchardispval_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:447]
ERROR: [Synth 8-448] named port connection 'gt0_txusrclk_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:449]
ERROR: [Synth 8-448] named port connection 'gt0_txusrclk2_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:450]
ERROR: [Synth 8-448] named port connection 'gt0_txelecidle_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:452]
ERROR: [Synth 8-448] named port connection 'gt0_txprbsforceerr_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:454]
ERROR: [Synth 8-448] named port connection 'gt0_txbufstatus_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:456]
ERROR: [Synth 8-448] named port connection 'gt0_txdiffctrl_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:458]
ERROR: [Synth 8-448] named port connection 'gt0_txdata_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:460]
ERROR: [Synth 8-448] named port connection 'gt0_gthtxn_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:462]
ERROR: [Synth 8-448] named port connection 'gt0_gthtxp_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:463]
ERROR: [Synth 8-448] named port connection 'gt0_txoutclk_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:465]
ERROR: [Synth 8-448] named port connection 'gt0_txoutclkfabric_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:466]
ERROR: [Synth 8-448] named port connection 'gt0_txoutclkpcs_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:467]
ERROR: [Synth 8-448] named port connection 'gt0_txpcsreset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:469]
ERROR: [Synth 8-448] named port connection 'gt0_txpmareset_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:470]
ERROR: [Synth 8-448] named port connection 'gt0_txresetdone_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:471]
ERROR: [Synth 8-448] named port connection 'gt0_txpmaresetdone_in' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:472]
ERROR: [Synth 8-448] named port connection 'gt0_txpolarity_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:474]
ERROR: [Synth 8-448] named port connection 'gt0_txprbssel_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:476]
ERROR: [Synth 8-448] named port connection 'gt0_txresetdone_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:478]
ERROR: [Synth 8-448] named port connection 'gt0_rxresetdone_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:479]
ERROR: [Synth 8-448] named port connection 'gt0_txcharisk_out' does not exist for instance 'pcs_pma_i' of module 'one_gig_eth_pcs_pma' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:482]
INFO: [Synth 8-6157] synthesizing module 'one_gig_eth_pcs_pma_resets' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_resets.v:63]
INFO: [Synth 8-5534] Detected attribute (* ASYNC_REG = "TRUE" *) [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_resets.v:74]
ERROR: [Synth 8-6156] failed synthesizing module 'one_gig_eth_pcs_pma_resets' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_resets.v:63]
ERROR: [Synth 8-6156] failed synthesizing module 'one_gig_eth_pcs_pma_support' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/support/one_gig_eth_pcs_pma_support.v:64]
ERROR: [Synth 8-6156] failed synthesizing module 'one_gig_eth_pcs_pma_example_design' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/ip_catalog/one_gig_pcs_pma/one_gig_eth_pcs_pma_example_design.v:60]
ERROR: [Synth 8-196] conditional expression could not be resolved to a constant [C:/one_gig_ten_gig_switchable_ip/hardware/sources/hdl/1g_10g_switchable.v:623]
ERROR: [Synth 8-6156] failed synthesizing module 'eth_1g_10g_switchable' [C:/one_gig_ten_gig_switchable_ip/hardware/sources/hdl/1g_10g_switchable.v:42]
Finished RTL Elaboration : Time (s): cpu = 00:00:06 ; elapsed = 00:00:06 . Memory (MB): peak = 1409.391 ; gain = 0.000
RTL Elaboration failed
63 Infos, 15 Warnings, 0 Critical Warnings and 89 Errors encountered.
synth_design failed
ERROR: [Vivado_Tcl 4-5] Elaboration failed - please see the console for details
Please guide.
Solved by changing the divider attributes value.
Tags (2)
take a look at @borisq answer
this document is so helpful, mark his answer as a solution if you understand what should you do, or ask your misunderstanding.
