dje666
Clock spec for 10GEMAC and 12G-SDI IP cores
Dear Forum,
For the 10GEMAC and 12G-SDI IP cores, do Xilinx publish a clock spec for the external clock sources that will be used to drive these cores?
DJE666
roym
If you're talking about the source for GT reference clocks, they are talked about in the GT user guides and a phase noise spec can be found in data sheet.  Basically it has to be LVDS or LVPECL and meet the phase noise specs.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
karnanl
Hello @dje666
Just adding my two cents. Datasheet for your device should cover phase spec requirement for your GT REFCLK.
For example if you are using Kintex US+ GTH then refer to Table 55 for this information.
Leo
karnanl
Hello @dje666
Do you have any updates on this post ?
If you find @roym 's  answer is useful, could you please kindly marked this thread as Solved , so other users can learn from your experience ?
Thanks & regards
Leo
