ttzotzaros
Constraining GTY transceiver on Virtex Ultrascale device
Hello
I have designed a 10Gbps PHY which drives an SFP. The design uses a GTY transceiver generated from the wizard, a 64/66b scrambler/descrambler, a block sync state machine and encoder/decoder.
My FPGA is a Virtex Ultrascale XCVU125.
When I implement the design, I get the following warning (DRC tab)
TIMING #1 Warning The clocks rxoutclk_out[0] and txoutclk_out[0] are related (timed together) but they have no common node. The design could fail in hardware. To find a timing path between these clocks, run the following command: report_timing -from [get_clocks rxoutclk_out[0]] -to [get_clocks txoutclk_out[0]]
How I constraint these clocks? I have read in https://www.xilinx.com/support/answers/64351.html, that for Ultrascale devices, no constraint is needed.
Thank you in advance
gguasti
hello
the RXOUTCLK phase is not known by Vivado, as it is modified by the Phase Interpolator. The message I take from Vivado is that two clock domains with unknown phase relationship are clocking the same logic. You should check what this logic is doing.
It might be a synchronizer, in this case everything is expected. Otherwise it could be a true error.
hope it helps
gguasti
hello,
if the two clock domains are completely independent (no logic in common) I think you could disregard this warning
ttzotzaros
Thank you for your reply
In fact there is a small bit of logic between these two clocks, but it is outside of a GT wrapper.
Should I discard this warning?
When I run report_timing I get these:
Timing Report
Slack (MET) :             4.668ns  (required time - arrival time)
  Source:                 PHY/decoder_64b66b/c7_reg/C
                            (rising edge-triggered cell FDCE clocked by rxoutclk_out[0]  {rise@0.000ns fall@3.200ns period=6.400ns})
  Destination:            probe3_1_reg[7]/D
                            (rising edge-triggered cell FDRE clocked by txoutclk_out[0]  {rise@0.000ns fall@3.200ns period=6.400ns})
  Path Group:             txoutclk_out[0]
  Path Type:              Setup (Max at Slow Process Corner)
  Requirement:            6.400ns  (txoutclk_out[0] rise@6.400ns - rxoutclk_out[0] rise@0.000ns)
  Data Path Delay:        2.354ns  (logic 0.117ns (4.970%)  route 2.237ns (95.030%))
  Logic Levels:           0
  Clock Path Skew:        0.598ns (DCD - SCD + CPR)
    Destination Clock Delay (DCD):    2.003ns = ( 8.403 - 6.400 )
    Source Clock Delay      (SCD):    1.405ns
    Clock Pessimism Removal (CPR):    0.000ns
  Clock Uncertainty:      0.035ns  ((TSJ^2 + TIJ^2)^1/2 + DJ) / 2 + PE
    Total System Jitter     (TSJ):    0.071ns
    Total Input Jitter      (TIJ):    0.000ns
    Discrete Jitter          (DJ):    0.000ns
    Phase Error              (PE):    0.000ns
  Clock Net Delay (Source):      1.019ns (routing 0.092ns, distribution 0.927ns)
  Clock Net Delay (Destination): 1.673ns (routing 0.557ns, distribution 1.116ns)
    Location             Delay type                Incr(ns)  Path(ns)    Netlist Resource(s)
                         (clock rxoutclk_out[0] rise edge)
                                                      0.000     0.000 r
    GTYE3_CHANNEL_X0Y36  GTYE3_CHANNEL                0.000     0.000 r  PHY/gt_transceiver/gtwizard_ultrascale_0_inst/inst/gen_gtwizard_gtye3_top.gtwizard_ultrascale_0_gtwizard_gtye3_inst/gen_gtwizard_gtye3.gen_channel_container[9].gen_enabled_channel.gtye3_channel_wrapper_inst/channel_inst/gtye3_channel_gen.gen_gtye3_channel_inst[0].GTYE3_CHANNEL_PRIM_INST/RXOUTCLK
                         net (fo=2, routed)           0.071     0.071    PHY/gt_transceiver/gtwizard_ultrascale_0_inst/inst/gen_gtwizard_gtye3_top.gtwizard_ultrascale_0_gtwizard_gtye3_inst/gen_gtwizard_gtye3.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/rxoutclk_out[0]
    BUFG_GT_X0Y217       BUFG_GT (Prop_BUFG_GT_I_O)
                                                      0.315     0.386 r  PHY/gt_transceiver/gtwizard_ultrascale_0_inst/inst/gen_gtwizard_gtye3_top.gtwizard_ultrascale_0_gtwizard_gtye3_inst/gen_gtwizard_gtye3.gen_rx_user_clocking_internal.gen_single_instance.gtwiz_userclk_rx_inst/gen_gtwiz_userclk_rx_main.bufg_gt_usrclk_inst/O
    X0Y9 (CLOCK_ROOT)    net (fo=297, routed)         1.019     1.405    PHY/decoder_64b66b/rx_clk
    SLICE_X3Y548         FDCE                                         r  PHY/decoder_64b66b/c7_reg/C
    SLICE_X3Y548         FDCE (Prop_DFF2_SLICEL_C_Q)
                                                      0.117     1.522 r  PHY/decoder_64b66b/c7_reg/Q
                         net (fo=1, routed)           2.237     3.759    xgmii_rxc[7]
    SLICE_X4Y549         FDRE                                         r  probe3_1_reg[7]/D
                         (clock txoutclk_out[0] rise edge)
                                                      6.400     6.400 r
    GTYE3_CHANNEL_X0Y36  GTYE3_CHANNEL                0.000     6.400 r  PHY/gt_transceiver/gtwizard_ultrascale_0_inst/inst/gen_gtwizard_gtye3_top.gtwizard_ultrascale_0_gtwizard_gtye3_inst/gen_gtwizard_gtye3.gen_channel_container[9].gen_enabled_channel.gtye3_channel_wrapper_inst/channel_inst/gtye3_channel_gen.gen_gtye3_channel_inst[0].GTYE3_CHANNEL_PRIM_INST/TXOUTCLK
                         net (fo=2, routed)           0.047     6.447    PHY/gt_transceiver/gtwizard_ultrascale_0_inst/inst/gen_gtwizard_gtye3_top.gtwizard_ultrascale_0_gtwizard_gtye3_inst/gen_gtwizard_gtye3.gen_tx_user_clocking_internal.gen_single_instance.gtwiz_userclk_tx_inst/txoutclk_out[0]
    BUFG_GT_X0Y216       BUFG_GT (Prop_BUFG_GT_I_O)
                                                      0.283     6.730 r  PHY/gt_transceiver/gtwizard_ultrascale_0_inst/inst/gen_gtwizard_gtye3_top.gtwizard_ultrascale_0_gtwizard_gtye3_inst/gen_gtwizard_gtye3.gen_tx_user_clocking_internal.gen_single_instance.gtwiz_userclk_tx_inst/gen_gtwiz_userclk_tx_main.bufg_gt_usrclk_inst/O
    X0Y8 (CLOCK_ROOT)    net (fo=589, routed)         1.673     8.403    tx_clk
    SLICE_X4Y549         FDRE                                         r  probe3_1_reg[7]/C
                         clock pessimism              0.000     8.403
                         clock uncertainty           -0.035     8.368
    SLICE_X4Y549         FDRE (Setup_DFF_SLICEL_C_D)
                                                      0.059     8.427    probe3_1_reg[7]
                         required time                          8.427
                         arrival time                          -3.759
                         slack                                  4.668
gguasti
hello
hope it helps
logictable
It looks like you are probing something in the RX datapath with the TX clock. Are you sure this is what you want?
