Visitor daihaohuazhu
Does GTH QPLL support 3.125Gpbs, 5Gbps line rate?
Does QPLL support 3.125Gpbs, 5Gbps lane rate?
My Project needs to support line rate change dynamicly. However, 3 types of lane rate are indeed: 3.125Gbps, 5Gpbs, 10Gpbs.
ug476 said GTH QPLL only supports lane rate >8Gbps. Can I use it in 3.125Gbps anyway? What problem will occur? QPLL unlock?
Thank you!
Re: Does GTH QPLL support 3.125Gpbs, 5Gbps line rate?
Hi @daihaohuazhu,
your picture shows the frequency range of the QPLL. This is not the usable line rate range. There are additional output divider which extend this.
Please have a look at ds183, table 70. Here you can find the supported line rates for the used output divider settings.
Hi @daihaohuazhu,
Thank you very much!!
