FPGA clock input
If FPGA has a high speed (GHz) external interface, is there any suggestion for FPGA clock input frequency (reference input clock for PLL)
  • should it be LVDS instead of single ended
  • can it be low frequency as 20MHz or is it suggested to have high frequency like 200MHz
Re: FPGA clock input
The MGT reference clock must have very low jitter.  For this reason, it is not recommended to use a FPGA internal PLL to generate the reference clock.
Your MGT transceivers require a reference clock that is typically greater than 100MHz.   The exact frequency depends on what function are using the transceivers to perform, Ethernet, chip-to-chip bridge, etc.   When must specify the reference clock frequency when you add the core to your design and configure it in Vivado.
@kinkeads thank you for your reply.
Can I supply this 100MHz+ clock frequency using the Xilinx PLL and feeding the internal PLL with external 25MHz clock input?
