gskumar
GT Debugger tool fails to open in Windows mode
I'm trying to invoke GT Debugger tool in windows mode. It fails while executing the startup script. Pl. find the sceen shot attached. Pl. kindly suggest how to fix this.
thanks,
sunil
csattar
hi @gskumar ,
Thanks for the update , kindly close the thread .
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
csattar
hello @gskumar ,
is the Environment Variable GTDBG for Windows created ? can you let me know path where it is created ?
Chandra sekhar
gskumar
Hi Chandra,
I could resolve this issue. The GTDBG env variable was set properly. But I found other issues.
1. In the gt_dbg tool properties, the Xilinx tool path was not correct (pl. see the attached screenshot). It was showing as 2017.2, but I was using 2018.3. I manually edited this.
2. I created one temp folder under c:\
With this, I was able to invoke the tool successfully.
rgds,
sunil
csattar
hi @gskumar ,
Chandra sekhar
