GTH clock route issue
Hello Everyone,
Design facing the issue in implementation upon changing the transceiver lane selection in physical resources tab og GT wizaed.
Attached is the current selection of physical resources of GTH. I followed UG917's page no. 40 for clock settings.
Quad 228:
• MGTREFCLK0 - FMC_HPC_GBTCLK0_M2C_C_P/N clock
• MGTREFCLK1 - FMC_HPC_GBTCLK1_M2C_C_P/N clock
• Contains four GTH transceivers allocated to FMC_HPC_DP[3:0]_C2M/M2C_P/N
I set MGTREFCLK1 with GTBTCLK1 comes from FMC.
The design takes too much time in implementation & at the end, it gives delay violations.
Can anyone guide me or correct me for GTH's setting of the lane?
Re: GTH clock route issue
With FPGA pin D2 D6, design successfully implemented. Without changing the timing constraints of the design.
your clock selection is what is said in ug917 (as you mentioned) and all things seem OK.
can you declare what is your application? and what is the schematic of your design?
tell us about your design timing constraints.
hi
The choice of GT dedicated REFCLK route should not affect timing in fabric.
Please check the timing report and see what is the real problem. Maybe the problem is due to the TX/RXUSRCLK frequency?
Thanks, @gguasti for the quick response.
I verified the timing report, constraints are given to take care of the timing-related path.
Meanwhile, With the same design I tried to implement with different settings of GT that is from one of my design.
Attached is a screenshot of GT configuration for which my design get successfully implemented.
I don't understand where the issue with previous settings.
Could you show us the violation net and route? Is it from type interpath or intrapath?
Do you have any other constraint that changes with changing the design?
If this post was helpful, don't forget to give kudos, reply and accept as solution.
