xilinx-gloh
GTH short circuit protection
Kintec Ultrascale KU060. Is the GTH Tx output short circuit protected?
jhua
Please refer to UG576 v1.6 Page 336. Unused TX pins should be left unconnected. In addition, the transmitter should be AC coupled.
Jessica
Versal Blogs
xilinx-gloh
Thank you for response. I was aware of this recommendation, but we use the GTH as an output external to a unit. So we have the possibilities to ac-couple at both sides Tx and Rx, or only once in the link.
If both sides are ac-coupled a dedicated drain resistor is needed to avoid floating static charging. But this implementaion is not easy to apply at higher data rates.
If only one side is ac-coupled the posibility of short circuit Tx or Rx to GND is a potential risk. Therefore my question, what the consequence is in case of a short circuit.
jhua
Hi @xilinx-gloh
If you have a DC blocking cap between the TX output and GND, there is no issue.
Jessica
Versal Blogs
