zhlimpcas
GTH transceivers issue
device: Kintex UltraScale
issue: GTH is performing data transmission simulation, the data fragments are misaligned. Use example design.
Transceivers wizard setting as follow:
Start from scratch, Lane rate: 10G, Ref. Clock = 156.25M, Encoding: 8b/10b, User data width: 64, TXOUTCLK/RXOUTCLK source:TXPROGDIVCLK/TXPROGDIVCLK,
Optional features as shown in figure:
Others are default。
TX data:
RX data:
Like this pattern:
XX AB CD EF XX =>XX BX DA FC EX XX
How to solve this problem?Please.
kdeshwal
Hi @zhlimpcas ,
Check and share all "RX Byte and Word Alignment " ports from UG576 (page-243) as well as RXCTRL0,RXCTRL1,RXCTRL2 & RXCTRL3.
Refer RX Byte and Word Alignment and RX 8B/10B Decoder section from UG576 for details.
Kuldeep
Please give Kudo and Accept as a Solution if solution provided seems helpful.
Have a look at our Versal Design Process Hub, Versal Blogs and the Versal Forum Useful Resources
zhlimpcas
Thanks for your reply!
I have checked the interfaces as you mentioned and simulated them to get the following results.
These are the simulation results of before alignment.
These are the simulation results after alignment.
I don't understand that the Comma code moves backward by 4 bytes and is spliced with the data.
Thanks!
