GTP COMPONENT INSTANTIATION
Hello
I am generation GTP IP for Vby1 application.
I can generate the IP(gtwizard_0) but I couldnt fine the instantiation templete. where it is in design sources in Vivado? Pls refer the snap shot.
Also how can I instantiate this IP in by design files?
Manish
Hello @manb
Please check the following folder for VHDL output def file :
project_***/project_***.srcs/sources_1/ip/gtwizard_0/gtwizard_0.vho
Is this file what you are looking for ?
You can instansiate GTP on your design as usual.
( gtpwizard_0.vhd is the top module of this IP )
Thanks & regards
Leo
