GTP Eye Scan Time Scale
The ES_HORZ_OFFSET description in table 4-20 of ug482 talks about changing the offset in terms of UI. Is any way to find out what the scale is in seconds?
Re: GTP Eye Scan Time Scale
hi @jamesgabauer_og ,
the scale in seconds depends on the line rate your link is running at. You should know what this is and then you know what time it takes for one UI. ES_HORZ_OFFSET spans one UI, so you can then divide down what one step of ES_HORZ_OFFSET is.
