GTP Eye Scan Voltage Levels
The ES_VERT_OFFSET description in table 4-20 of ug482 states that it controls the magnitude of the voltage offset but what is the actual voltage range that it is doing this over. As far as I could see this wasn't mentioned in the UG. Thank you
回复: GTP Eye Scan Voltage Levels
hi @jamesgabauer_og
one step is about 2mV.
Boris
hi @jamesgabauer_og
Boris
