GTP Line rate
I am using Vivado 2017.4.1 to configure a xc7a200tfbg484-1 chip with 7 Series Transceiver Wizard (3.6). Specs suggest that the GTP line rate can go up to 6.6 gbps, though the wizard is limiting me to 3.75.
What could be wrong?
Tags (3)
hi,
it is the speedgrade (-1) you are using.
DS181 specifies for -1 a max datarate of 3.75Gbps.
6.6Gbps can be reached with -2 and -3
hi,
