dick0329
GTP RXLPM_INCM_CFG and RXLPM_IPCM_CFG use for different VCM
I use GTP RX and set RX_CM_SEL[1:0] = 2'b10 (float mode) in my design,
I don't know how to set GTP RXLPM_INCM_CFG and RXLPM_IPCM_CFG for different VCM,
My design need receive differential signal with VCM possible range from 0.3V to 0.9V (not dynamic change),
I have read below AR but not suitable for my application,
https://www.xilinx.com/support/answers/51448.html
What is the VCM ranges for RXLPM_INCM_CFG and RXLPM_IPCM_CFG?
Does only one of RXLPM_INCM_CFG and RXLPM_IPCM_CFG must set to 1'b1 (can not both set to 1'b1 or 1'b0)?
Thank You~
gguasti
hello,
The AC-coupling is recommended. If you must use the DC-coupling, please be careful with common mode currents. The receiver bias should match the signal common mode and the two ports
RXLPM_INCM_CFG
RXLPM_IPCM_CFG
are needed to enable the high/low common mode operation.
I do not find a characterization for common mode from 0.3V to <0.8V
At 0.3V I would try with
RXLPM_INCM_CFG = 0
RXLPM_IPCM_CFG = 1
RX_CM_TRIM [3:0] = 4’b0011 – 300 mV
RX_CM_SEL [1:0] = 2'b11
Because it is very close to Use mode 1 (table 4-3). Unfortunately I have no additional data. Please check with a PRBS checker the link quality. (https://www.xilinx.com/support/documentation/application_notes/xapp884_PRBS_GeneratorChecker.pdf)
From 0.8 to 0.9V (please see the UG) you can use the following configuration:
RXLPM_INCM_CFG = 1
RXLPM_IPCM_CFG = 0
RX_CM_TRIM [3:0] = 4’b1010 – 800 mV
RX_CM_TRIM [3:0] = 4’b1011 – 850 mV
RX_CM_TRIM [3:0] = 4’b1100 – 900 mV
hope this helps
venkata
Which protocol are you trying to implement? Are you trying to do DC coupling with GTP?
Whether the termination mode "programmable" is suitable for you?
dick0329
This protocols are used for Panel Manufacturer to drive Source Driver IC (Such CHPI, CMPI, iSP, ...),
All of this protocols use DC Couple, but have different VCM (0.3V ~ 0.9V) and line rate (1.3Gbps ~ 3Gbps),
Those protocols need 100ohm termination resistor in RX side and have already described in standard spec,
I think "programmable mode" cannot be used, so I set RX_CM_SEL[1:0] = 2'b10 to use "float mode",
Unfortunately, RX_CM_TRIM[3:0] can not use in "float mode",
How GT know the current receiving VCM voltage, and choose suitable internal bias voltage in push-push mode configuration?
venkata
XAPP1096 provides an analysis for DC coupling use case with 7-series GTX. Check if it helps for your requirement.
https://www.xilinx.com/support/documentation/application_notes/xapp1096-dc-coupling-gtx-transceivers.pdf
gguasti
hello,
RXLPM_INCM_CFG
RXLPM_IPCM_CFG
RXLPM_INCM_CFG = 0
RXLPM_IPCM_CFG = 1
RXLPM_INCM_CFG = 1
RXLPM_IPCM_CFG = 0
hope this helps
dick0329
@gguasti
It work well, Thanks~
