Visitor k_uno_sli
GTP RXOUTCLK frequency
I am facing the incorrect GTP RXOUTCLK frequency against expected in the silicon(XC7A35TFGG484-2).
I implemented both GTP Tx and Rx as following spec;
Datarate: 0.75Gbps
Data width: 20
Then, I connect between Tx and Rx port via SMA cable and start to transmitting the 8b10b coded data. However, the recovered data is wrong, and the RXOUTCLK frequency is 46.9MHz I confirmed. It is multiplied by 1.25 of expected(37.5MHz), so I guess the data width is set to 16 in GTP wrapper or somewhere, but I could not find such setting. And this design has been verified in the simulation with Xilinx AR #53561.
Please tell me how to solve this issue.
Tags (3)
Re: GTP RXOUTCLK frequency
Hi @k_uno_sli ,
please check that you did not accidentally interrupted an ongoing reset.
You could verify if you read address 0x11 before you apply the reset and check the value
For bits [13:11] you should find a value of '3' or '5' there depending on your bus width.
If you see '2' or '4' there, you interrupted the reset before.
The external width of the bus will be divisible by 8 if you have 8B10B encoding.  The RXOUTCLK would be set up to drive a 16 wide bus.
On the TX side there is a 1.25 multiplier between the rate at the TXDATAIN and the TXP data.  For every 16 bits at TXDATAIN there are 20 bits at the TXP pin.  Could this be where the multiplier comes in?
Hi @k_uno_sli ,
Visitor k_uno_sli
Hi Roy,
Thank you for the reply.
In my design, the 8b10b encoder/decoder of GTP transceiver are not used, and I implemented another 8b10b encoder/decoder to outside of the GTP. So I set the external bus width to 20 in the transceiver wizard.
On the silicon, TXOUTCLK frequency is 1/20 * datarate (37.5MHz) and also correct symbols can be observed on the differential pins (MGTP_TX_P/N), however RXOUTCLK freuquency is multiplied by 1.25 against TXOUTCLK. Also on the simulation, both TXOUTCLK and RXOUTCLK frequency is 1/20 * datarate as expected.
Best Regards,
Visitor k_uno_sli
Hi ,
Thank you for your great support.
I had recheck and correct reset control logic of my design according to the advice.
I can observe correct Rx data and clock frequency from GTP now.
Best Regards,
