GTP Transceiver TXOUTCLK Driving
Hello
I found following at page 81 of  the user guide for 4 byte mode. The TXUSRCLK/TXUSRCLK2 is driving by TXOUTCLK.
My question is
In this mode MMCME2 is instantiated by application code or it is instantiated by itself and no need to do in application code?
Manish
Re: GTP Transceiver TXOUTCLK Driving
Hello Manish@manb
GTP user is responsible to supply TXUSRCLK/TXUSRCLK2.
so if you are using GTP Transceiver wizard, the wizard will not instatiate MMCM inside the IP,
But you can generate Example Design for your reference (which include an MMCM)
Leo
hi
This is MMCM that generate Txusrclk/Txusrclk2 in GT
I made some changes because of my design.
You can find that in example design with gt_usrclk_source.
Good luck
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
library UNISIM;
use UNISIM.VCOMPONENTS.ALL;
--***********************************Entity Declaration*******************************
entity GBT_GT_USRCLK_SOURCE is
port
GT0_TXUSRCLK_OUT : out std_logic;
GT0_TXUSRCLK2_OUT : out std_logic;
GT0_TXUSRCLK8_OUT : out std_logic;
GT0_TXOUTCLK_IN : in std_logic;
GT0_TXCLK_LOCK_OUT : out std_logic;
GT0_TX_MMCM_RESET_IN : in std_logic;
GT0_RXUSRCLK_OUT : out std_logic;
GT0_RXUSRCLK2_OUT : out std_logic;
GT0_RXUSRCLK8_OUT : out std_logic;
GT0_RXOUTCLK_IN : in std_logic;
GT0_RXCLK_LOCK_OUT : out std_logic;
GT0_RX_MMCM_RESET_IN : in std_logic;
Q1_CLK0_GTREFCLK_PAD_N_IN : in std_logic;
Q1_CLK0_GTREFCLK_PAD_P_IN : in std_logic;
Q1_CLK0_GTREFCLK_OUT : out std_logic
end GBT_GT_USRCLK_SOURCE;
architecture RTL of GBT_GT_USRCLK_SOURCE is
component GBT_CLOCK_MODULE is
generic
MULT : real := 2.0;
DIVIDE : integer := 2;
CLK_PERIOD : real := 6.4;
OUT0_DIVIDE : real := 2.0;
OUT1_DIVIDE : integer := 2;
OUT2_DIVIDE : integer := 2;
OUT3_DIVIDE : integer := 2
port
(-- Clock in ports
-- Clock out ports
CLK0_OUT : out std_logic;
CLK1_OUT : out std_logic;
CLK3_OUT : out std_logic;
-- Status and control signals
MMCM_LOCKED_OUT : out std_logic
end component;
--*********************************Wire Declarations**********************************
signal tied_to_ground_i : std_logic;
signal tied_to_vcc_i : std_logic;
signal gt0_txoutclk_i : std_logic;
signal gt0_rxoutclk_i : std_logic;
attribute syn_noclockbuf : boolean;
signal q1_clk0_gtrefclk : std_logic;
attribute syn_noclockbuf of q1_clk0_gtrefclk : signal is true;
signal gt0_txusrclk_i : std_logic;
signal gt0_txusrclk2_i : std_logic;
signal gt0_txusrclk8_i : std_logic;
signal gt0_rxusrclk_i : std_logic;
signal gt0_rxusrclk2_i : std_logic;
signal gt0_rxusrclk8_i : std_logic;
signal txoutclk_mmcm0_locked_i : std_logic;
signal txoutclk_mmcm0_reset_i : std_logic;
signal gt0_txoutclk_to_mmcm_i : std_logic;
signal rxoutclk_mmcm1_locked_i : std_logic;
signal rxoutclk_mmcm1_reset_i : std_logic;
signal gt0_rxoutclk_to_mmcm_i : std_logic;
begin
--*********************************** Beginning of Code *******************************
-- Static signal Assigments
tied_to_ground_i <= '0';
tied_to_vcc_i <= '1';
gt0_txoutclk_i <= GT0_TXOUTCLK_IN;
gt0_rxoutclk_i <= GT0_RXOUTCLK_IN;
Q1_CLK0_GTREFCLK_OUT <= q1_clk0_gtrefclk;
--IBUFDS_GTE2
ibufds_instq1_clk0 : IBUFDS_GTE2
port map
O => q1_clk0_gtrefclk,
ODIV2 => open,
CEB => tied_to_ground_i,
I => Q1_CLK0_GTREFCLK_PAD_P_IN,
IB => Q1_CLK0_GTREFCLK_PAD_N_IN
-- Instantiate a MMCM module to divide the reference clock. Uses internal feedback
-- for improved jitter performance, and to avoid consuming an additional BUFG
txoutclk_mmcm0_reset_i <= GT0_TX_MMCM_RESET_IN;
txoutclk_mmcm0_i : GBT_CLOCK_MODULE
generic map
MULT => 4.0,
DIVIDE => 1,
CLK_PERIOD => 6.25,
OUT0_DIVIDE => 4.0,
OUT1_DIVIDE => 2,
OUT2_DIVIDE => 16,
OUT3_DIVIDE => 1
port map
CLK0_OUT => gt0_txusrclk2_i,
CLK1_OUT => gt0_txusrclk_i,
CLK2_OUT => gt0_txusrclk8_i,
CLK3_OUT => open,
CLK_IN => gt0_txoutclk_i,
MMCM_LOCKED_OUT => txoutclk_mmcm0_locked_i,
MMCM_RESET_IN => txoutclk_mmcm0_reset_i
rxoutclk_mmcm1_reset_i <= GT0_RX_MMCM_RESET_IN;
rxoutclk_mmcm1_i : GBT_CLOCK_MODULE
generic map
MULT => 2.0,
DIVIDE => 1,
CLK_PERIOD => 3.125,
OUT0_DIVIDE => 4.0,
OUT1_DIVIDE => 2,
OUT2_DIVIDE => 16,
OUT3_DIVIDE => 1
port map
CLK0_OUT => gt0_rxusrclk2_i,
CLK1_OUT => gt0_rxusrclk_i,
CLK2_OUT => gt0_rxusrclk8_i,
CLK3_OUT => open,
CLK_IN => gt0_rxoutclk_i,
MMCM_LOCKED_OUT => rxoutclk_mmcm1_locked_i,
MMCM_RESET_IN => rxoutclk_mmcm1_reset_i
GT0_TXUSRCLK_OUT <= gt0_txusrclk_i;
GT0_TXUSRCLK2_OUT <= gt0_txusrclk2_i;
GT0_TXUSRCLK8_OUT <= gt0_txusrclk8_i; --gt0_rxusrclk8_i; --gt0_txusrclk8_i;
GT0_TXCLK_LOCK_OUT <= txoutclk_mmcm0_locked_i;
GT0_RXUSRCLK_OUT <= gt0_rxusrclk_i;
GT0_RXUSRCLK2_OUT <= gt0_rxusrclk2_i;
GT0_RXUSRCLK8_OUT <= gt0_rxusrclk8_i;
GT0_RXCLK_LOCK_OUT <= rxoutclk_mmcm1_locked_i;
end RTL;
