GTX 7 series transciever
I used 7 series transciever for 10.24 Gbps ( 64 bit data width ) interface bitween 2 KC705 and It works excellent. Thanks Xilinx company for developing such IPcore.
But I have some issues with this IPcore in 3.2 Gbps - 20 bit data width. In simulation  recieved data (rx_data) is not true. I know about bit slip but rx_data is completely wrong even gt0_rxslide_i can not help in this settings.
Also I have one special problem with this IPcore in 3.84 Gbps (32 bit data width), Simulation is good But occasionally when I write (program) bit file in KC705, rx_data is not true (it is not confirm tx_data even with bit slip). Is there something wrong with this Ipcore in low rate or data width except 64 bit???
Thanks alot for your time and consideration.
Best Regards
Hard to say what could be going wrong.  Could you attach the *.XCI file for the designs that won't work?
