GTX/GTH transciever of kintex 7
Hi xilinx team.
In my kintex 7 XC7k160t FBG676 GTX/GTH transciever requiremnts is not there in project application, so should i have to tie up some pins of this banks if i am not using these banks or what ? what is the correct procedure please let me know.
and i reffered UG476 but i am clear with that.
Thank you.
Re: GTX/GTH transciever of kintex 7
You can find the attached '7_Series_Schematic_Review_Recommendations'. xilinx recommended whaht to be done with the unused pins of GTX/GTR.
Best Regards,
--Ashok
Thank you
you can use
set_property BITSTREAM.GENERAL.UNCONSTRAINEDPINS Allow [current_design]
set_property BITSTREAM.CONFIG.UNUSEDPIN pullup [current_design]
to pullup your unconstrained pins. But be aware of using it while your unused pins are connected to any other module on your board.
If this post was helpful, don't forget to give kudos, reply and accept as solution.
