Visitor railcannon
GTX RX pin grounded then RX_CM_SEL Floating or Ground?
Hello
I have a single simple question about RX_CM_SEL
I build FPGA PCB  with GTX RX pins directly tied to ground because I'm not using GTX RX pins.
Datasheet saids if a receiver is not used and not biased, connect the RX pin pair to ground.
Then what should I set the RX_CM_SEL to make not biased.
GND or FLOATING?
I think both are correct configuration.
Am I right?
Re: GTX RX pin grounded then RX_CM_SEL Floating or Ground?
Hi @railcannon ,
as you clearly do not want to use these inputs, do not instantiate anything on that location in your design. You do not need to set anything.
Please also have a look at AR71407.
