GTX gen1 to gen3 switching
Hi Team,
I successfully completed PCIe Gen1 using GTX as RAW Serdes using "xc7k160tffg676-2" custom board. Thank you for your support.
Now i want to use GTX as RAW Serdes for both Gen1 and Gen3 also .
1. For that i need to switch GTX from Gen1 to Gen3
2. Previously I generated GTX ip core using cpll with rate 2.5 Gbps, now I generated 8.0Gbps.
My Controller will provide rate change signals
What I need to do for switching GTX from Gen1 to Gen3
Thank you
Krishna
Re: GTX gen1 to gen3 switching
You need to use DRP to write attributes to switch between these 2 designs. Assuming you have 2 designs built, one with Gen1 and one with Gen3. Use the attached script, run on an implemented design. It will dump all GT attributes to a gtParam.txt file. You can then use text compare software (or diff) to find out the attribute differences.
When you are ready to switch rates, apply the DRP writes, then assert reset_all.
Hi jhua,
Thank you for your valuable reply, but i didn't get any attached script here. I am using UG476 for GTX reference.
Can we write those attributes using registers?
and also can you please elaborate more on how to use scripts ?
1) at which stage should i source these scripts (after PNR or during running on hw with hw_manager)
2) will the scripts change the clk values and other attributes of the design or simply dump the gtx parameters file just for comparison purpose ?
3) Suppose if I am using DRP i/f , are these scripts still required ?
4) please also point which DRP ports i need to change for switching the rate .
5) please also let me know what are the parameters should i change b/w gen1 to gen3 and vice versa.
hi c.gannamani@gmail.com
the script is just dumping the attributes for you to compare.
so that you can identify the attributes or ports that need to be changed.
Boris
Hi Boris,
Thanks for the Information, but i didn't get any attached script here. Please provide the scripts.
Thank you
Krishnachaitanya
you can find some useful tcl scripts here.
https://www.xilinx.com/support/answers/56137.html
the one you are looking for is gt_Attributes.tcl.
Boris
Got the script file.
I initiated the GTX ip core for 8.0 Gbps rate with qpll. When I tried to enable CPLL for Gen1 operation, unable to get the both TXOUTCLK and RXOUTCLK (also tx/rx usrclk's).My question is: Can I switch GTX from Gen1 to Gen3 by generating one instance of IP core.
+FYI,
My GTX generated Settings attached
Hi, I am wondering how the 7 series transciever IP can be used to do PCIe communication. As far as I understand,7 series transciever IP does not include protocol. Do you mean you use to  7 series transciever IP as well as the protocol related module?
Hi c.gannamani@gmail.com
Are you able to operate with QPLL at 2.5Gbps?
If you attempted to switch from QPLL to CPLL when changing Gen3 -> Gen1, can you describe the list of attributes and ports you changed?
Hi greatmaverick,
I am using GTX transceiver wizard 3.6 as RAW serdes only, i am using our own controller and PIPE modules.
Krishnachaitanya
Hi Jhua,
I am unable to operate with QPLL at 2.5Gbps.
Actually i want to establish Gen1 operation first and then Gen3, so I configured IP core for maximum data rate with QPLL.
I thought when i changed the tx/rx sysclksel[1:0] it will switch from QPLL to CPLL, But it is not changing(i checked in Simulation).
Is it possible to switch GTX from Gen1 to Gen3 by configuring IP core for maximum data rate with QPLL?
you need to generate two IPs by the transceiver wizard.
first is 2.5Gbps with CPLL, the other is 8Gbps with QPLL1.
compare the attributes & ports and identify diffs and switch between the two.
Boris
here is the baseline step
https://www.xilinx.com/support/answers/31968.html
