Visitor upside_down
GTY transceiver TX buffer and TX phase allignment
I am reading the user guide of GTY transceivers (ug578). In page 138 it talks about TX buffer bypassing, and there is corresponding figure which should show the corresponding datapath (Figure 3-18, screenshot is attached below).
I am not sure which block is TX buffer and which one is TX phase alignment block (I have a guess but I want to be sure). I need to know the exact blocks to understand the dataflow path when TX buffer is bypassed.
Which part/block is TX buffer and which one is TX phase alignment?
Re: GTY transceiver TX buffer and TX phase allignment
Hi @upside_down ,
the TX buffer is the phase adjust FIFO in the diagram. The phase alignment circuit for buffer bypass is not explicitely drawn in that diagram.
Hi @upside_down ,
