michi.b
GTY4 Select TXOUTCLK for RXOUTCLK
I have a question regarding the GTY4 TXOUTCLK & RXOUTCLK.
In GTX it was simple to provide the TXOUTCLK as RXUSRCLK to use this as 'RXOUTCLK', too.
I want to create the same using GTY4, but in the GT-Wizard there is no possibility to select the RXOUTCLK source from the TXOUTCLK.
Is there a possibility to do this via DRP or do I have to manually modify the generated .v files to create this connection?
Best regards,
  Michael
Tags (2)
roym
If you put the clocking into the example design it is very easy to make this change.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
roym
