hpoetzl
Voyager
Voyager
Glitch in eye scan?
Looking at those beautiful eye scans generated by Vivado via the IBERT core ...
MGT Eye ScanMGT Eye Scan... I'm wondering what causes the glitch in the middle where looks like either the bottom or the top part is shifted down by about 10%.
I'm pretty confident that the actual signal eye doesn't look like this but the effect is very consistent, i.e. it shows up in all eye scan diagrams I've done with Vivado/IBERT yet.
Is this a one-off error in the software or some weird effect in the way the sample point voltage is configured or maybe something completely different I haven't even considered yet?
Thanks in advance,
Herbert
-------------- Yes, I do this for fun!
roym
I've never seen this sort of problem.  I can only guess that the equalization is adapting during the scan causing this.  I would suggest holding the various CDR and equalization attributes and seeing if holding one of them makes this go away.  Also does changing from LPM to DFE or vice versa affect the scan.
See tables 4-9 and 4-10 of UG578 to see the hold attributes for GTY.  Other transceivers should have similar tables.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
hpoetzl
Voyager
Voyager
Hello Roy!
That is quite interesting, because I see it all the time not just occasionally
I set all the *HOLD port properties to 1 but the effect didn't change.
I also verified that those settings are actually active by changing from pattern to fast clock which really gives bad results until I un-hold those settings ...
As far as I can tell, there is no DFE for GTP tranceivers (UG482)
eye_scan_hold
hpoetzl
Voyager
Voyager
After artificially closing the eye, by playing around with the transmitter settings, I was able to obtain some really nice scans showing the problem in all detail ...
xc7a50t_6G_eyescan_1
xc7a50t_6G_eyescan_2
xc7a50t_6G_eyescan_3
gguasti
What you are measuring is probably due to two different RX configurations. The eye scan loop is much slower than the RX adaptation loop. I would agree with Roy.
have you tried with setting the RXOSHOLD=1 as well?
hpoetzl
Voyager
Voyager
Not sure why the ES_VERT_OFFSET should affect the RX adaptation or equalization, maybe you can elaborate on that ...
Yes, as can be seen in the Vivado Screenshot I posted earlier.
But because the glitches are so nice, here is a new one again with all *HOLD port properties set for both tranceivers involved in the links.
xc7a50t_6G_eyescan_hold
jlantz
If you set the eyescan to do 100% of the horizontal scale (UI) and 100% of the vertical scale (codes) does it do the same thing?  For this test you can do increments of 4 on both to speed up the scan.
hpoetzl
Voyager
Voyager
Yup, the same (only smaller :) with a full scan ...
xc7a50t_6G_eyescan_full
jlantz
Is this an optical or electrical interconnect?
hpoetzl
Voyager
Voyager
electrical.
gguasti
the eye scan loop is not "affecting" the adaptation loop. But they happen at the same time.
It is possible that while the eye scan is running, and this operation takes a very long time, the equalizer adapts to a better setup. As result, you have the overlap of two half eyes: the first half is with equalization A, and the second half is with equalization B.
I mentioned RXOSHOLD because it is not listed in GTP UG, UG482 table 4-9 (equalizer), but it appears only at table 4-11 (CDR ports). Thus is possible that in testing we forget about this port.
However in your eyescans I see the glitch always happening at the passage by vertical offset  = 0. I cannot explain this. A change in the equalization would affect the eye at random vertical level.
could you please repeat the scan, only for that subregion where the glitch happens?
thanks
hpoetzl
Voyager
Voyager
Not sure how to run the scan only for an offcenter subregion but I certainly can zoom in with Vivado ...
Here some closeups of the glitch:
xc7a50t_6G_eyescan_zoom
travisc
Can you do an export on the raw data on one of these strange eyes? Just right click on the eye and select export, then hopefully you can attach it here. It might be usefull to see both ends of the spectrum, a plot with many samples, and one with very few samples.
hpoetzl
Voyager
Voyager
Sure, here is a new scan (default and heatmap) together with the CSV data ...
xc7a50t_6G_eyescan_csv
xc7a50t_6G_eyescan_heatmap
