How to achieve electrical idle state in GTP of ARTIX 7 during SATA2.0 initialization?
I am trying to do link initialization using GTP of ARTIX 7-1 FGG676 for SATA2.0 with a 32 GB SSD.
The protocol says [as per xapp870 - It would be very nice if any one provide some reference of SATA2.0 work using GTP, if simlarly published somewhere] that after power up, put the lines to common mode voltage and then issue COMRESET.
1) I raise TXELECIDLE = '1' continuously.
2) I raise TXCOMINIT = '1' then
I do not find bursts of ALIGNp when I do so in simulation.
But If I do not use TXELECIDLE, i.e keep = 0. I see bursts in simulation.
Now My doubts are :-
1) Whether TXELECIDLE is at all useful in this case [as it is mentioned in exclusive for PCI]. If so how to use it for SATA link initialization? Or whether this is a simulation bug - and even if it so, please indicate the correct usage of it.
2) When should i raise GTP line to common mode voltage, after GTP reset and initialization or during that time as well. My hidden fear is that whether before OOB, any data at all should be seen by SSD after power up i.e. whether ELECTRICAL IDLE STATE should be maintained before and during OOB.
Will be very grateful if any help in this regard. Further I am very disheartened that with ready ARTIX 7 hardware, I am not finding any app note which gives clear idea for SATA2.0 development using GTP as this is hampering our timeline of product development in a major way.
Re: How to achieve electrical idle state in GTP of ARTIX 7 during SATA2.0 initialization?
My further doubts are what is the value i should set for Tx side common mode voltage for sata2.0 some where i have seen 800mV, other places I have seen 200mV etc.
I am using ISE14.5
Ok, even if i am unable to convey what I am saying:-
Can some one tell me whether I need to pass any data on TXDATA_IN[15:0] of GTP during OOB. This confusion arises because the code given in XAPP870, does pass ALIGNp during OOB. Is it at all required
I wish someone could / would reply here so that we could proceed a bit.
What setting in GTP is not allowing to get RXCOMDET :-
    gtpe2_i : GTPE2_CHANNEL
    generic map
        --_______________________ Simulation-Only Attributes ___________________
        SIM_RECEIVER_DETECT_PASS   =>      ("TRUE"),
        SIM_RESET_SPEEDUP          =>      (GT_SIM_GTRESET_SPEEDUP),
        SIM_TX_EIDLE_DRIVE_LEVEL   =>      ("X"),
        SIM_VERSION                =>      ("1.0"),
       ------------------RX Byte and Word Alignment Attributes---------------
        ALIGN_COMMA_DOUBLE                      =>     ("FALSE"),
        ALIGN_COMMA_ENABLE                      =>     ("1111111111"),
        ALIGN_COMMA_WORD                        =>     (1),
        ALIGN_MCOMMA_DET                        =>     ("TRUE"),
        ALIGN_MCOMMA_VALUE                      =>     ("1010000011"),
        ALIGN_PCOMMA_DET                        =>     ("TRUE"),
        ALIGN_PCOMMA_VALUE                      =>     ("0101111100"),
        SHOW_REALIGN_COMMA                      =>     ("FALSE"),
        RXSLIDE_AUTO_WAIT                       =>     (7),
        RXSLIDE_MODE                            =>     ("PCS"),
        RX_SIG_VALID_DLY                        =>     (10),
       ------------------RX 8B/10B Decoder Attributes---------------
        RX_DISPERR_SEQ_MATCH                    =>     ("TRUE"),
        DEC_MCOMMA_DETECT                       =>     ("TRUE"),
        DEC_PCOMMA_DETECT                       =>     ("TRUE"),
        DEC_VALID_COMMA_ONLY                    =>     ("FALSE"),
       ------------------------RX Clock Correction Attributes----------------------
        CBCC_DATA_SOURCE_SEL                    =>     ("DECODED"),
        CLK_COR_SEQ_2_USE                       =>     ("FALSE"),
        CLK_COR_KEEP_IDLE                       =>     ("FALSE"),
        CLK_COR_MAX_LAT                         =>     (9),
        CLK_COR_MIN_LAT                         =>     (7),
        CLK_COR_PRECEDENCE                      =>     ("TRUE"),
        CLK_COR_REPEAT_WAIT                     =>     (0),
        CLK_COR_SEQ_LEN                         =>     (1),
        CLK_COR_SEQ_1_ENABLE                    =>     ("1111"),
        CLK_COR_SEQ_1_1                         =>     ("0000000000"),
        CLK_COR_SEQ_1_2                         =>     ("0000000000"),
        CLK_COR_SEQ_1_3                         =>     ("0000000000"),
        CLK_COR_SEQ_1_4                         =>     ("0000000000"),
        CLK_CORRECT_USE                         =>     ("FALSE"),
        CLK_COR_SEQ_2_ENABLE                    =>     ("1111"),
        CLK_COR_SEQ_2_1                         =>     ("0000000000"),
        CLK_COR_SEQ_2_2                         =>     ("0000000000"),
        CLK_COR_SEQ_2_3                         =>     ("0000000000"),
        CLK_COR_SEQ_2_4                         =>     ("0000000000"),
       ------------------------RX Channel Bonding Attributes----------------------
        CHAN_BOND_KEEP_ALIGN                    =>     ("FALSE"),
        CHAN_BOND_MAX_SKEW                      =>     (1),
        CHAN_BOND_SEQ_LEN                       =>     (1),
        CHAN_BOND_SEQ_1_1                       =>     ("0000000000"),
        CHAN_BOND_SEQ_1_2                       =>     ("0000000000"),
        CHAN_BOND_SEQ_1_3                       =>     ("0000000000"),
        CHAN_BOND_SEQ_1_4                       =>     ("0000000000"),
        CHAN_BOND_SEQ_1_ENABLE                  =>     ("1111"),
        CHAN_BOND_SEQ_2_1                       =>     ("0000000000"),
        CHAN_BOND_SEQ_2_2                       =>     ("0000000000"),
        CHAN_BOND_SEQ_2_3                       =>     ("0000000000"),
        CHAN_BOND_SEQ_2_4                       =>     ("0000000000"),
        CHAN_BOND_SEQ_2_ENABLE                  =>     ("1111"),
        CHAN_BOND_SEQ_2_USE                     =>     ("FALSE"),
        FTS_DESKEW_SEQ_ENABLE                   =>     ("1111"),
        FTS_LANE_DESKEW_CFG                     =>     ("1111"),
        FTS_LANE_DESKEW_EN                      =>     ("FALSE"),
       ---------------------------RX Margin Analysis Attributes----------------------------
        ES_CONTROL                              =>     ("000000"),
        ES_ERRDET_EN                            =>     ("FALSE"),
        ES_EYE_SCAN_EN                          =>     ("FALSE"),
        ES_HORZ_OFFSET                          =>     (x"010"),
        ES_PMA_CFG                              =>     ("0000000000"),
        ES_PRESCALE                             =>     ("00000"),
        ES_QUALIFIER                            =>     (x"00000000000000000000"),
        ES_QUAL_MASK                            =>     (x"00000000000000000000"),
        ES_SDATA_MASK                           =>     (x"00000000000000000000"),
        ES_VERT_OFFSET                          =>     ("000000000"),
       -------------------------FPGA RX Interface Attributes-------------------------
        RX_DATA_WIDTH                           =>     (20),
       ---------------------------PMA Attributes----------------------------
        OUTREFCLK_SEL_INV                       =>     ("11"),
        PMA_RSV                                 =>     (x"00000333"),
        PMA_RSV2                                =>     (x"00002040"),
        PMA_RSV3                                =>     ("00"),
        PMA_RSV4                                =>     ("0000"),
        RX_BIAS_CFG                             =>     ("0000111100110011"),
        DMONITOR_CFG                            =>     (x"000A00"),
        RX_CM_SEL                               =>     ("11"),
        RX_CM_TRIM                              =>     ("1010"),
        RX_DEBUG_CFG                            =>     ("00000000000000"),
        RX_OS_CFG                               =>     ("0000010000000"), -- changed based on AR51369 - 0 0011 1111 0000
        TERM_RCAL_CFG                           =>     ("100001000010000"),
        TERM_RCAL_OVRD                          =>     ("000"),
        TST_RSV                                 =>     (x"00000000"),
        RX_CLK25_DIV                            =>     (7), -- may require a change
        TX_CLK25_DIV                            =>     (7), -- may require a change
        UCODEER_CLR                             =>     ('0'),
       ---------------------------PCI Express Attributes----------------------------
        PCS_PCIE_EN                             =>     ("FALSE"),
       ---------------------------PCS Attributes----------------------------
        PCS_RSVD_ATTR                           =>     (x"000000000100"),
       -------------RX Buffer Attributes------------
        RXBUF_ADDR_MODE                         =>     ("FAST"),
        RXBUF_EIDLE_HI_CNT                      =>     ("1000"),
        RXBUF_EIDLE_LO_CNT                      =>     ("0000"),
        RXBUF_EN                                =>     ("TRUE"), -- may require a change
        RX_BUFFER_CFG                           =>     ("000000"),
        RXBUF_RESET_ON_CB_CHANGE                =>     ("TRUE"),
        RXBUF_RESET_ON_COMMAALIGN               =>     ("FALSE"),
        RXBUF_RESET_ON_EIDLE                    =>     ("FALSE"),
        RXBUF_RESET_ON_RATE_CHANGE              =>     ("TRUE"),
        RXBUFRESET_TIME                         =>     ("00001"),
        RXBUF_THRESH_OVFLW                      =>     (61),
        RXBUF_THRESH_OVRD                       =>     ("FALSE"),
        RXBUF_THRESH_UNDFLW                     =>     (4),
        RXDLY_CFG                               =>     (x"001F"),
        RXDLY_LCFG                              =>     (x"030"),
        RXDLY_TAP_CFG                           =>     (x"0000"),
        RXPH_CFG                                =>     (x"C00002"),
        RXPHDLY_CFG                             =>     (x"084020"),
        RXPH_MONITOR_SEL                        =>     ("00000"),
        RX_XCLK_SEL                             =>     ("RXREC"), -- may require a change
        RX_DDI_SEL                              =>     ("000000"),
        RX_DEFER_RESET_BUF_EN                   =>     ("TRUE"),
       -----------------------CDR Attributes-------------------------
       --For GTX only: Display Port, HBR/RBR- set RXCDR_CFG=72'h0380008bff40200002
       --For GTX only: Display Port, HBR2 -   set RXCDR_CFG=72'h03000023ff10200020
        RXCDR_CFG                               =>     (x"0000047FE206024481010"), -- changed from "0000107FE206001041010" based on #AR51369 -- 0000047FE206024501010 as per UG -- 0_0000_47FE_2060_2448_1010
        RXCDR_FR_RESET_ON_EIDLE                 =>     ('0'),
        RXCDR_HOLD_DURING_EIDLE                 =>     ('0'),
        RXCDR_PH_RESET_ON_EIDLE                 =>     ('0'),
        RXCDR_LOCK_CFG                          =>     ("001001"),
       -------------------RX Initialization and Reset Attributes-------------------
        RXCDRFREQRESET_TIME                     =>     ("00001"),
        RXCDRPHRESET_TIME                       =>     ("00001"),
        RXISCANRESET_TIME                       =>     ("00001"),
        RXPCSRESET_TIME                         =>     ("00001"),
        RXPMARESET_TIME                         =>     ("00011"),
       -------------------RX OOB Signaling Attributes-------------------
        RXOOB_CFG                               =>     ("0000110"),
       -------------------------RX Gearbox Attributes---------------------------
        RXGEARBOX_EN                            =>     ("FALSE"),
        GEARBOX_MODE                            =>     ("000"),
       -------------------------PRBS Detection Attribute-----------------------
        RXPRBS_ERR_LOOPBACK                     =>     ('0'),
       -------------Power-Down Attributes----------
        PD_TRANS_TIME_FROM_P2                   =>     (x"03c"),
        PD_TRANS_TIME_NONE_P2                   =>     (x"3c"),
        PD_TRANS_TIME_TO_P2                     =>     (x"64"),
        SAS_MAX_COM                             =>     (64),
        SAS_MIN_COM                             =>     (36),
        SATA_BURST_SEQ_LEN                      =>     ("1111"), -- may require a change
        SATA_BURST_VAL                          =>     ("100"),  -- may require a change
        SATA_EIDLE_VAL                          =>     ("100"),  -- may require a change
        SATA_MAX_BURST                          =>     (8),
        SATA_MAX_INIT                           =>     (21),
        SATA_MAX_WAKE                           =>     (7),
        SATA_MIN_BURST                          =>     (4),
        SATA_MIN_INIT                           =>     (12),
        SATA_MIN_WAKE                           =>     (4),
       -------------RX Fabric Clock Output Control Attributes----------
        TRANS_TIME_RATE                         =>     (x"0E"),
       --------------TX Buffer Attributes----------------
        TXBUF_EN                                =>     ("TRUE"), -- may require a change
        TXBUF_RESET_ON_RATE_CHANGE              =>     ("TRUE"),
        TXDLY_CFG                               =>     (x"001F"),
        TXDLY_LCFG                              =>     (x"030"),
        TXDLY_TAP_CFG                           =>     (x"0000"),
        TXPH_CFG                                =>     (x"0780"),
        TXPHDLY_CFG                             =>     (x"084020"),
        TXPH_MONITOR_SEL                        =>     ("00000"),
        TX_XCLK_SEL                             =>     ("TXOUT"), -- may require a change
       -------------------------FPGA TX Interface Attributes-------------------------
        TX_DATA_WIDTH                           =>     (20),
       -------------------------TX Configurable Driver Attributes-------------------------
        TX_DEEMPH0                              =>     ("000000"),
        TX_DEEMPH1                              =>     ("000000"),
        TX_EIDLE_ASSERT_DELAY                   =>     ("110"),
        TX_EIDLE_DEASSERT_DELAY                 =>     ("100"),
        TX_LOOPBACK_DRIVE_HIZ                   =>     ("FALSE"),
        TX_MAINCURSOR_SEL                       =>     ('0'),
        TX_DRIVE_MODE                           =>     ("DIRECT"),
        TX_MARGIN_FULL_0                        =>     ("1001110"),
        TX_MARGIN_FULL_1                        =>     ("1001001"),
        TX_MARGIN_FULL_2                        =>     ("1000101"),
        TX_MARGIN_FULL_3                        =>     ("1000010"),
        TX_MARGIN_FULL_4                        =>     ("1000000"),
        TX_MARGIN_LOW_0                         =>     ("1000110"),
        TX_MARGIN_LOW_1                         =>     ("1000100"),
        TX_MARGIN_LOW_2                         =>     ("1000010"),
        TX_MARGIN_LOW_3                         =>     ("1000000"),
        TX_MARGIN_LOW_4                         =>     ("1000000"),
       -------------------------TX Gearbox Attributes--------------------------
        TXGEARBOX_EN                            =>     ("FALSE"),
       -------------------------TX Initialization and Reset Attributes--------------------------
        TXPCSRESET_TIME                         =>     ("00001"),
        TXPMARESET_TIME                         =>     ("00001"),
       -------------------------TX Receiver Detection Attributes--------------------------
        TX_RXDETECT_CFG                         =>     (x"1832"),
        TX_RXDETECT_REF                         =>     ("100"),
       ------------------ JTAG Attributes ---------------
        ACJTAG_DEBUG_MODE                       =>     ('0'),
        ACJTAG_MODE                             =>     ('0'),
        ACJTAG_RESET                            =>     ('0'),
       ------------------ CDR Attributes ---------------
        CFOK_CFG                                =>     (x"49000040E80"),
        CFOK_CFG2                               =>     ("0100000"),
        CFOK_CFG3                               =>     ("0100000"),
        CFOK_CFG4                               =>     ('0'),
        CFOK_CFG5                               =>     (x"0"),
        CFOK_CFG6                               =>     ("0000"),
        RXOSCALRESET_TIME                       =>     ("00011"),
        RXOSCALRESET_TIMEOUT                    =>     ("00000"),
       ------------------ PMA Attributes ---------------
        CLK_COMMON_SWING                        =>     ('0'),
        RX_CLKMUX_EN                            =>     ('1'),
        TX_CLKMUX_EN                            =>     ('1'),
        ES_CLK_PHASE_SEL                        =>     ('0'),
        USE_PCS_CLK_PHASE_SEL                   =>     ('0'),
        PMA_RSV6                                =>     ('0'),
        PMA_RSV7                                =>     ('0'),
       ------------------ TX Configuration Driver Attributes ---------------
        TX_PREDRIVER_MODE                       =>     ('0'),
        PMA_RSV5                                =>     ('0'),
        SATA_PLL_CFG                            =>     ("VCO_3000MHZ"),
       ------------------ RX Fabric Clock Output Control Attributes ---------------
        RXOUT_DIV                               =>     (2),
       ------------------ TX Fabric Clock Output Control Attributes ---------------
        TXOUT_DIV                               =>     (2),
       ------------------ RX Phase Interpolator Attributes---------------
        RXPI_CFG0                               =>     ("000"),
        RXPI_CFG1                               =>     ('1'),
        RXPI_CFG2                               =>     ('1'),
       --------------RX Equalizer Attributes-------------
        ADAPT_CFG0                              =>     (x"00000"),
        RXLPMRESET_TIME                         =>     ("0001111"),
        RXLPM_BIAS_STARTUP_DISABLE              =>     ('0'),
        RXLPM_CFG                               =>     ("0110"),
        RXLPM_CFG1                              =>     ('0'),
        RXLPM_CM_CFG                            =>     ('0'),
        RXLPM_GC_CFG                            =>     ("111100010"),
        RXLPM_GC_CFG2                           =>     ("001"),
        RXLPM_HF_CFG                            =>     ("00001111110000"),
        RXLPM_HF_CFG2                           =>     ("01010"),
        RXLPM_HF_CFG3                           =>     ("0000"),
        RXLPM_HOLD_DURING_EIDLE                 =>     ('0'),
        RXLPM_INCM_CFG                          =>     ('1'),
        RXLPM_IPCM_CFG                          =>     ('0'),
        RXLPM_LF_CFG                            =>     ("000000001111110000"),
        RXLPM_LF_CFG2                           =>     ("01010"),
        RXLPM_OSINT_CFG                         =>     ("100"), -- "000" changed based on AR51369
       ------------------ TX Phase Interpolator PPM Controller Attributes---------------
        TXPI_CFG0                               =>     ("00"),
        TXPI_CFG1                               =>     ("00"),
        TXPI_CFG2                               =>     ("00"),
        TXPI_CFG3                               =>     ('0'),
        TXPI_CFG4                               =>     ('0'),
        TXPI_CFG5                               =>     ("000"),
        TXPI_GREY_SEL                           =>     ('0'),
        TXPI_INVSTROBE_SEL                      =>     ('0'),
        TXPI_PPMCLK_SEL                         =>     ("TXUSRCLK2"),
        TXPI_PPM_CFG                            =>     (x"00"),
        TXPI_SYNFREQ_PPM                        =>     ("000"), -- may be changed
       ------------------ LOOPBACK Attributes---------------
        LOOPBACK_CFG                            =>     ('0'),
        PMA_LOOPBACK_CFG                        =>     ('0'),
       ------------------RX OOB Signalling Attributes---------------
        RXOOB_CLK_CFG                           =>     ("PMA"),
       ------------------TX OOB Signalling Attributes---------------
        TXOOB_CFG                               =>     ('0'),
       ------------------RX Buffer Attributes---------------
        RXSYNC_MULTILANE                        =>     ('0'),
        RXSYNC_OVRD                             =>     ('0'),
        RXSYNC_SKIP_DA                          =>     ('0'),
       ------------------TX Buffer Attributes---------------
        TXSYNC_MULTILANE                        =>     (TXSYNC_MULTILANE_IN),
        TXSYNC_OVRD                             =>     (TXSYNC_OVRD_IN),
        TXSYNC_SKIP_DA                          =>     ('0')
    port map
                                --------------------------------- CPLL Ports -------------------------------
        GTRSVD                          =>      "0000000000000000",
        PCSRSVDIN                       =>      "0000000000000000",
        TSTIN                           =>      "11111111111111111111",
        ---------------------------- Channel - DRP Ports  --------------------------
        DRPADDR                         =>      drpaddr_i,
        DRPCLK                          =>      DRPCLK_IN,
        DRPDI                           =>      drpdi_i,
        DRPDO                           =>      drpdo_i,
        DRPEN                           =>      drpen_i,
        DRPRDY                          =>      drprdy_i,
        DRPWE                           =>      drpwe_i,
        ----------------- FPGA TX Interface Datapath Configuration  ----------------
        TX8B10BEN                       =>      tied_to_vcc_i,
        ------------------------ GTPE2_CHANNEL Clocking Ports ----------------------
        PLL0CLK                         =>      PLL0CLK_IN,
        PLL0REFCLK                      =>      PLL0REFCLK_IN,
        PLL1CLK                         =>      PLL1CLK_IN,
        PLL1REFCLK                      =>      PLL1REFCLK_IN,
        RXSYSCLKSEL                     =>      "11",
        TXSYSCLKSEL                     =>      "11",
        ------------------------------- Loopback Ports -----------------------------
        LOOPBACK                        =>      tied_to_ground_vec_i(2 downto 0),
        ----------------------------- PCI Express Ports ----------------------------
        PHYSTATUS                       =>      open,
        RXRATE                          =>      tied_to_ground_vec_i(2 downto 0),
        RXVALID                         =>      open,
        ----------------------------- PMA Reserved Ports ---------------------------
        PMARSVDIN3                      =>      '0',
        PMARSVDIN4                      =>      '0',
        ------------------------------ Power-Down Ports ----------------------------
        RXPD                            =>      "00",
        TXPD                            =>      "00",
        -------------------------- RX 8B/10B Decoder Ports -------------------------
        SETERRSTATUS                    =>      tied_to_ground_i,
        --------------------- RX Initialization and Reset Ports --------------------
        EYESCANRESET                    =>      tied_to_ground_i,
        RXUSERRDY                       =>      RXUSERRDY_IN,
        -------------------------- RX Margin Analysis Ports ------------------------
        EYESCANDATAERROR                =>      EYESCANDATAERROR_OUT,
        EYESCANMODE                     =>      tied_to_ground_i,
        EYESCANTRIGGER                  =>      tied_to_ground_i,
        ------------------------------- Receive Ports ------------------------------
        CLKRSVD0                        =>      tied_to_ground_i,
        CLKRSVD1                        =>      tied_to_ground_i,
        DMONFIFORESET                   =>      tied_to_ground_i,
        DMONITORCLK                     =>      tied_to_ground_i,
        RXPMARESETDONE                  =>      rxpmaresetdone_t,
        SIGVALIDCLK                     =>      tied_to_ground_i,
        ------------------------- Receive Ports - CDR Ports ------------------------
        RXCDRFREQRESET                  =>      tied_to_ground_i,
        RXCDRHOLD                       =>      tied_to_ground_i,
        RXCDRLOCK                       =>      RXCDRLOCK_OUT,
        RXCDROVRDEN                     =>      tied_to_ground_i,
        RXCDRRESET                      =>      tied_to_ground_i,
        RXCDRRESETRSV                   =>      tied_to_ground_i,
        RXOSCALRESET                    =>      tied_to_ground_i,
        RXOSINTCFG                      =>      "0010",
        RXOSINTDONE                     =>      open,
        RXOSINTHOLD                     =>      tied_to_ground_i,
        RXOSINTOVRDEN                   =>      tied_to_ground_i,
        RXOSINTPD                       =>      tied_to_ground_i,
        RXOSINTSTARTED                  =>      open,
        RXOSINTSTROBE                   =>      tied_to_ground_i,
        RXOSINTSTROBESTARTED            =>      open,
        RXOSINTTESTOVRDEN               =>      tied_to_ground_i,
        ------------------- Receive Ports - Clock Correction Ports -----------------
        RXCLKCORCNT                     =>      open,
        ---------- Receive Ports - FPGA RX Interface Datapath Configuration --------
        RX8B10BEN                       =>      tied_to_vcc_i,
        ------------------ Receive Ports - FPGA RX Interface Ports -----------------
        RXDATA                          =>      rxdata_i,
        RXUSRCLK                        =>      RXUSRCLK_IN,
        RXUSRCLK2                       =>      RXUSRCLK2_IN,
        ------------------- Receive Ports - Pattern Checker Ports ------------------
        RXPRBSERR                       =>      open,
        RXPRBSSEL                       =>      tied_to_ground_vec_i(2 downto 0),
        ------------------- Receive Ports - Pattern Checker ports ------------------
        RXPRBSCNTRESET                  =>      tied_to_ground_i,
        ------------------ Receive Ports - RX 8B/10B Decoder Ports -----------------
        RXCHARISCOMMA                   =>      open,
        RXCHARISK(3 downto 2)           =>      rxcharisk_float_i,
        RXCHARISK(1 downto 0)           =>      RXCHARISK_OUT,
        RXDISPERR(3 downto 2)           =>      rxdisperr_float_i,
        RXDISPERR(1 downto 0)           =>      RXDISPERR_OUT,
        RXNOTINTABLE(3 downto 2)        =>      rxnotintable_float_i,
        RXNOTINTABLE(1 downto 0)        =>      RXNOTINTABLE_OUT,
        ------------------------ Receive Ports - RX AFE Ports ----------------------
        GTPRXN                          =>      GTPRXN_IN,
        GTPRXP                          =>      GTPRXP_IN,
        PMARSVDIN2                      =>      '0',
        PMARSVDOUT0                     =>      open,
        PMARSVDOUT1                     =>      open,
        ------------------- Receive Ports - RX Buffer Bypass Ports -----------------
        RXBUFRESET                      =>      tied_to_ground_i,
        RXBUFSTATUS                     =>      open,
        RXDDIEN                         =>      tied_to_ground_i, -- may be changed
        RXDLYBYPASS                     =>      tied_to_vcc_i, -- may be changed
        RXDLYEN                         =>      tied_to_ground_i,
        RXDLYOVRDEN                     =>      tied_to_ground_i,
        RXDLYSRESET                     =>      tied_to_ground_i,
        RXDLYSRESETDONE                 =>      open,
        RXPHALIGN                       =>      tied_to_ground_i,
        RXPHALIGNDONE                   =>      open,
        RXPHALIGNEN                     =>      tied_to_ground_i,
        RXPHDLYPD                       =>      tied_to_ground_i,
        RXPHDLYRESET                    =>      tied_to_ground_i,
        RXPHMONITOR                     =>      open,
        RXPHOVRDEN                      =>      tied_to_ground_i,
        RXPHSLIPMONITOR                 =>      open,
        RXSTATUS                        =>      RXSTATUS_OUT,
        RXSYNCALLIN                     =>      tied_to_ground_i,
        RXSYNCDONE                      =>      open,
        RXSYNCIN                        =>      tied_to_ground_i,
        RXSYNCMODE                      =>      tied_to_ground_i,
        RXSYNCOUT                       =>      open,
        -------------- Receive Ports - RX Byte and Word Alignment Ports ------------
        RXBYTEISALIGNED                 =>      open,  -- should be used in the code
        RXBYTEREALIGN                   =>      open,
        RXCOMMADET                      =>      open,
        RXCOMMADETEN                    =>      tied_to_vcc_i,
        RXMCOMMAALIGNEN                 =>      tied_to_ground_i,
        RXPCOMMAALIGNEN                 =>      tied_to_ground_i,
        RXSLIDE                         =>      RXSLIDE_IN,
        ------------------ Receive Ports - RX Channel Bonding Ports ----------------
        RXCHANBONDSEQ                   =>      open,
        RXCHBONDEN                      =>      tied_to_ground_i,
        RXCHBONDI                       =>      "0000",
        RXCHBONDLEVEL                   =>      tied_to_ground_vec_i(2 downto 0),
        RXCHBONDMASTER                  =>      tied_to_ground_i,
        RXCHBONDO                       =>      open,
        RXCHBONDSLAVE                   =>      tied_to_ground_i,
        RXCHANISALIGNED                 =>      open,
        RXCHANREALIGN                   =>      open,
        ------------ Receive Ports - RX Decision Feedback Equalizer(DFE) -----------
        DMONITOROUT                     =>      open,
        RXADAPTSELTEST                  =>      tied_to_ground_vec_i(13 downto 0),
        RXDFEXYDEN                      =>      tied_to_ground_i,
        RXOSINTEN                       =>      '1',
        RXOSINTID0                      =>      tied_to_ground_vec_i(3 downto 0),
        RXOSINTNTRLEN                   =>      tied_to_ground_i,
        RXOSINTSTROBEDONE               =>      open,
        ------- Receive Ports - RX Driver,OOB signalling,Coupling and Eq.,CDR ------
        RXLPMLFOVRDEN                   =>      tied_to_ground_i,
        RXLPMOSINTNTRLEN                =>      tied_to_ground_i,
        --------------------- Receive Ports - RX Equalizer Ports -------------------
        RXOSHOLD                        =>      tied_to_ground_i,
        RXOSOVRDEN                      =>      tied_to_ground_i,
        --------------------- Receive Ports - RX Equilizer Ports -------------------
        RXLPMHFHOLD                     =>      RXLPMHFHOLD_IN,
        RXLPMHFOVRDEN                   =>      tied_to_ground_i,
        RXLPMLFHOLD                     =>      RXLPMLFHOLD_IN,
        ------------ Receive Ports - RX Fabric ClocK Output Control Ports ----------
        RXRATEDONE                      =>      open,
        ----------- Receive Ports - RX Fabric Clock Output Control Ports  ----------
        RXRATEMODE                      =>      '0',
        --------------- Receive Ports - RX Fabric Output Control Ports -------------
        RXOUTCLK                        =>      RXOUTCLK_OUT,
        RXOUTCLKFABRIC                  =>      open,
        RXOUTCLKPCS                     =>      open,
        RXOUTCLKSEL                     =>      "010",
        ---------------------- Receive Ports - RX Gearbox Ports --------------------
        RXDATAVALID                     =>      open,
        RXHEADER                        =>      open,
        RXHEADERVALID                   =>      open,
        RXSTARTOFSEQ                    =>      open,
        RXGEARBOXSLIP                   =>      tied_to_ground_i,
        ------------- Receive Ports - RX Initialization and Reset Ports ------------
        GTRXRESET                       =>      gtrxreset_out,
        RXLPMRESET                      =>      tied_to_ground_i,
        RXOOBRESET                      =>      tied_to_ground_i,
        RXPCSRESET                      =>      tied_to_ground_i,
        RXPMARESET                      =>      tied_to_ground_i,
        ------------------- Receive Ports - RX OOB Signaling ports -----------------
        RXCOMSASDET                     =>      open,
        RXCOMWAKEDET                    =>      RXCOMWAKEDET_OUT,
        RXCOMINITDET                    =>      RXCOMINITDET_OUT,
        ------------------ Receive Ports - RX OOB signalling Ports -----------------
        RXELECIDLE                      =>      RXELECIDLE_OUT,
        RXELECIDLEMODE                  =>      "00",
        ----------------- Receive Ports - RX Polarity Control Ports ----------------
        RXPOLARITY                      =>      tied_to_ground_i,
        -------------- Receive Ports -RX Initialization and Reset Ports ------------
        RXRESETDONE                     =>      RXRESETDONE_OUT,
        --------------------------- TX Buffer Bypass Ports -------------------------
        TXPHDLYTSTCLK                   =>      tied_to_ground_i,
        ------------------------ TX Configurable Driver Ports ----------------------
        TXPOSTCURSOR                    =>      "00000",
        TXPOSTCURSORINV                 =>      tied_to_ground_i,
        TXPRECURSOR                     =>      tied_to_ground_vec_i(4 downto 0),
        TXPRECURSORINV                  =>      tied_to_ground_i,
        -------------------- TX Fabric Clock Output Control Ports ------------------
        TXRATEMODE                      =>      tied_to_ground_i,
        --------------------- TX Initialization and Reset Ports --------------------
        CFGRESET                        =>      tied_to_ground_i,
        GTTXRESET                       =>      GTTXRESET_IN,
        PCSRSVDOUT                      =>      open,
        TXUSERRDY                       =>      TXUSERRDY_IN,
        ----------------- TX Phase Interpolator PPM Controller Ports ---------------
        TXPIPPMEN                       =>      tied_to_ground_i,
        TXPIPPMOVRDEN                   =>      tied_to_ground_i,
        TXPIPPMPD                       =>      tied_to_ground_i,
        TXPIPPMSEL                      =>      tied_to_ground_i,
        TXPIPPMSTEPSIZE                 =>      tied_to_ground_vec_i(4 downto 0),
        ---------------------- Transceiver Reset Mode Operation --------------------
        GTRESETSEL                      =>      tied_to_ground_i,
        RESETOVRD                       =>      tied_to_ground_i,
        ------------------------------- Transmit Ports -----------------------------
        TXPMARESETDONE                  =>      open,
        ----------------- Transmit Ports - Configurable Driver Ports ---------------
        PMARSVDIN0                      =>      '0',
        PMARSVDIN1                      =>      '0',
        ------------------ Transmit Ports - FPGA TX Interface Ports ----------------
        TXDATA                          =>      txdata_i,
        TXUSRCLK                        =>      TXUSRCLK_IN,
        TXUSRCLK2                       =>      TXUSRCLK2_IN,
        --------------------- Transmit Ports - PCI Express Ports -------------------
        TXELECIDLE                      =>      tied_to_ground_i,
        TXMARGIN                        =>      tied_to_ground_vec_i(2 downto 0),
        TXRATE                          =>      tied_to_ground_vec_i(2 downto 0),
        TXSWING                         =>      tied_to_ground_i,
        ------------------ Transmit Ports - Pattern Generator Ports ----------------
        TXPRBSFORCEERR                  =>      tied_to_ground_i,
        ------------------ Transmit Ports - TX 8B/10B Encoder Ports ----------------
        TX8B10BBYPASS                   =>      tied_to_ground_vec_i(3 downto 0),
        TXCHARDISPMODE                  =>      tied_to_ground_vec_i(3 downto 0),
        TXCHARDISPVAL                   =>      tied_to_ground_vec_i(3 downto 0),
        TXCHARISK(3 downto 2)           =>      tied_to_ground_vec_i(1 downto 0),
        TXCHARISK(1 downto 0)           =>      TXCHARISK_IN,
        ------------------ Transmit Ports - TX Buffer Bypass Ports -----------------
        TXDLYBYPASS                     =>      tied_to_vcc_i,
        TXDLYEN                         =>      tied_to_ground_i,
        TXDLYHOLD                       =>      tied_to_ground_i,
        TXDLYOVRDEN                     =>      tied_to_ground_i,
        TXDLYSRESET                     =>      tied_to_ground_i,
        TXDLYSRESETDONE                 =>      open,
        TXDLYUPDOWN                     =>      tied_to_ground_i,
        TXPHALIGN                       =>      tied_to_ground_i,
        TXPHALIGNDONE                   =>      open,
        TXPHALIGNEN                     =>      tied_to_ground_i,
        TXPHDLYPD                       =>      tied_to_ground_i,
        TXPHDLYRESET                    =>      tied_to_ground_i,
        TXPHINIT                        =>      tied_to_ground_i,
        TXPHINITDONE                    =>      open,
        TXPHOVRDEN                      =>      tied_to_ground_i,
        ---------------------- Transmit Ports - TX Buffer Ports --------------------
        TXBUFSTATUS                     =>      open,
        ------------ Transmit Ports - TX Buffer and Phase Alignment Ports ----------
        TXSYNCALLIN                     =>      tied_to_ground_i,
        TXSYNCDONE                      =>      open,
        TXSYNCIN                        =>      tied_to_ground_i,
        TXSYNCMODE                      =>      tied_to_ground_i,
        TXSYNCOUT                       =>      open,
        --------------- Transmit Ports - TX Configurable Driver Ports --------------
        GTPTXN                          =>      GTPTXN_OUT,
        GTPTXP                          =>      GTPTXP_OUT,
        TXBUFDIFFCTRL                   =>      "100",
        TXDEEMPH                        =>      tied_to_ground_i,
        TXDIFFCTRL                      =>      "1010",
        TXDIFFPD                        =>      tied_to_ground_i,
        TXINHIBIT                       =>      tied_to_ground_i,
        TXMAINCURSOR                    =>      "0000000",
        TXPISOPD                        =>      tied_to_ground_i,
        ----------- Transmit Ports - TX Fabric Clock Output Control Ports ----------
        TXOUTCLK                        =>      TXOUTCLK_OUT,
        TXOUTCLKFABRIC                  =>      TXOUTCLKFABRIC_OUT,
        TXOUTCLKPCS                     =>      TXOUTCLKPCS_OUT,
        TXOUTCLKSEL                     =>      "010",
        TXRATEDONE                      =>      open,
        --------------------- Transmit Ports - TX Gearbox Ports --------------------
        TXGEARBOXREADY                  =>      open,
        TXHEADER                        =>      tied_to_ground_vec_i(2 downto 0),
        TXSEQUENCE                      =>      tied_to_ground_vec_i(6 downto 0),
        TXSTARTSEQ                      =>      tied_to_ground_i,
        ------------- Transmit Ports - TX Initialization and Reset Ports -----------
        TXPCSRESET                      =>      tied_to_ground_i,
        TXPMARESET                      =>      tied_to_ground_i,
        TXRESETDONE                     =>      TXRESETDONE_OUT,
        ------------------ Transmit Ports - TX OOB signalling Ports ----------------
        TXCOMFINISH                     =>      TXCOMFINISH_OUT,
        TXCOMINIT                       =>      TXCOMINIT_IN,
        TXCOMSAS                        =>      tied_to_ground_i,
        TXCOMWAKE                       =>      TXCOMWAKE_IN,
        TXPDELECIDLEMODE                =>      tied_to_ground_i,
        ----------------- Transmit Ports - TX Polarity Control Ports ---------------
        TXPOLARITY                      =>      tied_to_ground_i,
        --------------- Transmit Ports - TX Receiver Detection Ports  --------------
        TXDETECTRX                      =>      tied_to_ground_i,
        ------------------ Transmit Ports - pattern Generator Ports ----------------
        TXPRBSSEL                       =>      tied_to_ground_vec_i(2 downto 0)
To initiate TXCOMINIT, you may not require to assert TXELECIDLE.
The frequency of the OOB clock should satisfy the following requirement.
f ≤ Linerate / (3 x Runlength)
Also, the user guide recommends to follow the guidance from figure 4-14 to understand RXELECIDLE behavior correctly.
Hi venkat,
Can you tell me when RXELECIDLE will go low. It is mentioned in the UG that Activity on RX lines make it low - Does it mean OOB Burts only or whether it is also for normal data received on RX lines as well.
IS my understanding correct -
RXELECIDLE= '0' for OOB Bursts as well as Normal In band Data on Rx lines
RXELECIDLE = '1' when it is electrically idle i.e. in between bursts during OOB.
Your quick revert on this will help us save lot of time
I agree with your understanding
Have you solved this problem ? I also want to know how to send OOB signal by K-7 Transceiver?
for example  I want send COMRESET signal ,i assert COMRESET = 1 ,and until the output COMFINISH is "1" ,i deassert COMRESET =0 ; if it rignt? shold i do anything about TXELECIDLE?
