jiongsi
How to run IBERT test on two AC701 boards
I need run IBERT test on two AC701 boards,
1. how should I connect the PMA cables?
TX_P1->TX_P2, TX_N1->TX_N2,  RX_P1->RX_P2, RX_N1->RX_N2?
OR
TX_P1->RX_P2, TX_N1->RX_N2,  TX_P2->RX_P1, TX_N2->RX_N1?
2. which loopback mode should I choose?
3. do I need to assign TX/RX pins of the IBERT IP design to FPGA pins?
Thanks a lot.
eschidl
Hi @jiongsi ,
your second connection approach is correct, TX1->RX2 and TX2->RX1.
as you have a direct connection you do not need to set any loopback.
If you selected the correct transceiver/quad when generating the IBERT design, the transceivers will be placed correctly and you do not need to set anything for the TX/RX data pins. Check the reference clock and system clock setup though.
eschidl
Hi @jiongsi ,
jiongsi
@eschidlthank you for your reply.
Both boards work well when I set the TX/RX Pattern as PRBS 7-bit on both boards,and both boards can receive the other one's error inject.
But one boards doesn't work (there are a lot of Errors) if I set TX/RX Pattern to other bits.
Does the TX/RX Patterns matter?
eschidl
Hi @jiongsi ,
yes, you need matching pattern at both sides. The TX should send the same pattern that the RX expects, Otherwise error testing would not make sense.
jiongsi
Hi @eschidl ,
Yes, I changed every TX/RX on both boards to the same PRBS pattern, but still one board works, the other always has errors.
I found PRBS 7-bit pattern also has occasional errors.
Fast Clk and Slow Clk patterns don't have errors so far.
eschidl
Hi @jiongsi ,
can it be that you use the EPHYCLK of the board as reference clock for a 6.25Gbps link? This is meant for 1G Etherent connections. If yes, can you try to use the SMA reference clock connection with an external clock generator or the jitter attenuator?
jiongsi
Hi @eschidl ,
I am not sure what's EPHYCLK... here is my clock settings:
I don't have an external clock generator, can only use the on board oscillator.
eschidl
Hi @jiongsi ,
check with UG952, page 25 for the clocking. You will see the EPHYCLK there. It is the on board 125MHz clock.
Could you borrow a clock generator and use the SMA refclk input then?
Or could you try a lower line rate?
