IBERT on VCU108
I am trying to evaluate GTY transceivers between 2 VCU108 boards with the IBERT IP (I am using the QUAD126 with a Bullseye connector on both sides).
When I am working in differential, everything is OK.
 But when I use them in single-ended-like scheme (only “_P” are connected), I have 2 kinds of figure:
  1. When the “_N” are left floating, everything is OK.
  2. When a 50 Ohm adaptation is placed on each “_N”, it is NOK (channels are not even locking)
 I tried 2 IBERT configurations and they are both giving these same results mentioned above. These configurations are:
  1. Link Coupling : AC + programmable termination = 800 mV
  2. Link coupling : DC + floating termination
Correct me if I am wrong but there is no AC coupling on the VCU108 board right?
 To be clear, my final goal is to make these links work with only the positive parts (“_P”). How could that be done?
Thank you for your guidance
Tags (4)
Re: IBERT on VCU108
Hello @ultrascaleaddict
Your understanding is correct.
Xilinx Transceivers (including GTY) are designed and tested to work with differential connectivity configuration. There is no guarantee that GTY will work with single-ended configuration, channels will have less margin. I am wondering how the IBERT EyeScan diagram looks like on your board.
Please consider to use HP I/O bank instead for single-ended.
Thanks & regards
Leo
