Observer anilsutej
IBIS AMI ARTIX-7 GTP: No RX Die model Available
As per the following link
https://www.xilinx.com/support/answers/71949.html
"The testbench must include die termination models (which model the on-die characteristics) and the package models. When simulating for a custom channel, just replace the example channel s-parameter model with the actual channel model.
The end-to-end channel should include 5 components:
TX die termination -> TX package -> channel -> RX package -> RX die termination."
But in the downloaded S-Parameter file there is no TX/RX die termination model available.
But only folloing files are there in the s-paramters folder
Please suggest for 7 sereies GTP model do we need to consider the RX/TX die model or not.
I tried without that but the IBIS-AMI Channel Analysis in Hyperlynx is failing.
Please suggest as we have to qualify the board for 3 Gbps and results are not as expected.
Anil
Re: IBIS AMI ARTIX-7 GTP: No RX Die model Available
Hello
the die model was embedded in the package in this IBIS AMI model.
For 7 sereies GTP model there is no need to consider the RX/TX die model.
what is the error message returned by HL?
thanks
Hello
thanks
Observer anilsutej
Thank you for the quick reply.
I the S-Port assignment was wrongly connected in my setup.
Now after changing the port order things are looking good.
Anil
