Voyager
Voyager
IBUFDS_GTE4 output drive generic logic, would it introduce jitter?
I am looking at sharing reference clocks between multiple QUADs, the same clock after IBUFDS_GTE4 to drive a lot of generic logic.
Don't know if this is a good idea or not.
I read from UG576, there are rules in limiting number of transceivers in using the reference clock.
Please comment.
Re: IBUFDS_GTE4 output drive generic logic, would it introduce jitter?
You cannot use the ODIV2 output of IBUFDS_GTE4 to drive general logic without using BUFG_GT. This clock buffer takes the reference clock to global clock routing.
The limitation mentioned in ug576, is related to the clock route driven by "O" output of IBUFDS_GTE4. This clock route is only used for driving transceivers. This is different from the global clock route driven by the ODIV2 output of IBUFDS_GTE4.
Voyager
Voyager
It seems gt_refclk_out is after BUFG_GT, is it possible to bring out refclk to be used by other QUAD, without changing 10G/25G subsystem core structure in a block design?
gt_refclk_out is the output of IBUFDS_GTE4 buffer. You will only tap it on the same quad, in which the clock is supplied.
I was referring to ODIV2 output in my previous post below.
Voyager
Voyager
Great thanks,
Voyager
Voyager
I have a design passed implementation.
It has QUADs taking reference clock from 10G.gt_refclk_out (which is output of BUFG_GT), also the clock is used by generic logic.
Is there any risk/increased jitter on my GT Quads to use this clock as reference input?
This usage has been followed by many customers. There is no issue with it.
Just want to clarify your usage. Can you please confirm?
I understand that you are using "ODIV2" for fabric logic and "O" for multiple quads.
Dear Forum,
Can this solution be setup using the Buf_Util blocks in the Vivado IPI, or does it require Verilog/VHDL instantiation? I have Util-buffers configured as IBUF-GTE feeding BUFG_GT, but no clock is getting to the logic.
TTFN.
DJE666
Schematic looks ok.....?
gte4_2_bufg_gt-sch.pngI Think....
DJE666
Hi dje666,
I think you are near the solution, simply don't put all other signals of the ds_buf to ground.
Take a look at this post:
https://forums.xilinx.com/t5/Serial-Transceivers/Zynq-Ultrascale-SMA-MGT-Clock-input/td-p/855914
Based on that simply put some constant block IP to give the right settings
Best Regars.
Can we drive the gt_ref_clk from IBUFDS_GTE4 to BUF_GT and then we can share ' O' ref_clk to other logic blocks?
beacuse i finding some issues like this...
[DRC REQP-1929] IBUFDS_GTE4_O_may_only_drive_GTxE4: The IBUFDS_GTE4 n10g_interface_inst/IBUFDS_GTE4_inst O pin may only be connected to the GTREFCLK pin of a GTHE4_COMMON, GTHE4_CHANNEL, GTYE4_COMMON, or GTYE4_CHANNEL component. The IBUFDS_GTE4 O pin cannot drive n10g_interface_inst/xgbaser_gt_wrapper_inst/bufhce_156_25_inst, and n10g_interface_inst/xgbaser_gt_wrapper_inst/i_ten_gig_eth_pcs_pma_ip_common_wrapper/ten_gig_eth_pcs_pma_ip_gt_gtye4_common_wrapper_i/common_inst/gtye4_common_gen.GTYE4_COMMON_PRIM_INST.
Hi @likith ,
you are replying to an old thread with a new topic. It would be better to open a new thread to get an answer.
If you look at ug576, page 25, you can see that the 'O' output in the IBUFDS_GTE4 can only drive *COMMON or *CHANNEL primitives. So the DRC message is correct if you try to connect it to a BUFG_GT.
Only the 'ODIV2 ' output has routings to BUFG_GT and can therefor drive fabric logic. With REFCLK_HROW_CK_SEL you can select what you will see at the output.
