shareef@phoelex.com
Issues running the IOModule examples
I'm trying to bring up a GTY transceiver using the IOModule.  I've built a BSP and thought I'd first try to run the examples that come with the IOModule.  These are in the directory Xilinx/SDK/2018.3/data/embeddedsw/XilinxProcessorIPLib/drivers/iomodule_v2_6/examples/ in my installation.
Of the two I've tried, one hangs and one fails to compile.
xiomodule_intr_example.c: this hangs somewhere during IOModuleDisableIntr().
xiomodule_low_level_example.c: this has a bunch of defines that don't exist and uses uint types that aren't recognised by the toolchain.
Should these examples be useable?  What should I be using to bring up the IOModule?
shareef@phoelex.com
shareef@phoelex.com
