oscar717
KCU105 SFP+ IBERT Test Failure
I am trying to run a sanity check on the SFP+ with the example design provided on the rdf0312-kcu105-gth-ibert-c-2017-3.zip (XTP345), but it keeps failing.
I verified the connections and the cable and everything seems fine.
I am specifically running the "ibert_sfp.tcl".
Here is a screenshot of the results:
Tags (3)
oscar717
The issue was that the clock Si570 was not programmed so I had to program it to output the 163MHz required for this test.
See solution in this thread:
https://forums.xilinx.com/t5/Serial-Transceivers/KCU105-QPLL-Common-X0Y2-Not-Locked/m-p/1120817#M8188
roym
There is an enable for the SFP on that board.  TX disable on page 22 of the schematic.  Make sure it is on -Y20 on page 3 of the schematic.
Be sure to visit the Resources post periodically to keep up with the latest
https://forums.xilinx.com/t5/Serial-Transceivers/Serial-Transceiver-Forum-Guidelines-and-Useful-Resources/td-p/1173590
oscar717
There is no "TX_DISABLE" on page 22 nor Y20 on page 3, however I verified that the SFPs were enabled and according to the schematic this is done by simply having the jumpers on J6 and J7 (As described in XTP352 Pg 10) . These are in pages 27 and 28 of the schematic.
eschidl
Hi @oscar717 ,
did you setup the reference clock correctly? Your PLLs are not locked from the picture.
oscar717
I am running the "ibert_sfp.tcl" file provided in the set of IBERT tests in XTP346 so I assumed that all reference clocks were set up correctly.
The other IBERT tests run successfully, it is only this ibert_sfp test that keeps failing.
Yes, COMMON_X0Y2 does not lock, but I don't know why. I tried the following tcl commands but that did not get the X0Y2 to lock:
set_property PORT.QPLL0RESET 1 [get_hw_sio_commons *];commit_hw_sio [list [get_hw_sio_commons {*}] ]
set_property PORT.QPLL0RESET 0 [get_hw_sio_commons *];commit_hw_sio [list [get_hw_sio_commons {*}] ]
set_property PORT.QPLL1RESET 1 [get_hw_sio_commons *];commit_hw_sio [list [get_hw_sio_commons {*}] ]
set_property PORT.QPLL1RESET 0 [get_hw_sio_commons *];commit_hw_sio [list [get_hw_sio_commons {*}] ]
refresh_hw_sio [get_hw_sio_gts *]
refresh_hw_sio [get_hw_sio_commons *]
oscar717
