KCU1500 IBERT
i builded ibert test project ,qsfp0_resetl is setted 1.and downed bit to kcu1500.insert qsfp to cage ,lookback mode is none ,no link .when near end pcs/pma, link up.why?thanks!
hello
can you measure any signal coming out  of the QSFP?
Hi~ I also want to IBERT ethernet looback test on KCU1500 board.
Have you done it? if u did it, could you please give me a hand?
I am using in-system-ibert to test it. I just wanna refer to your step, if you could share it.
Thanks!
hi @seanlj
try to assert RXRESET see what happens.
make sure RX termination voltage is set to 800mV
try to increase TXOUT_DIV and RXOUT_DIV to lower line rate
Boris
Boris,
do you have IBERT test project source for KCU1500 board?
Dmitrii
