nipunnaina
Kintex 7 GTX DRP ports example code required
I want to run time data-rate change for kintex7 gtx.
In past, I have used the example codes from xilinx for DRP functions for PLL and MMCM. These were simple verilog files.
I am unable to find any example DRP code for GTX reconfiguration. If it is available please provide the same. A verilog file will be preferred.
amaccre
HI @soulefmassoud,
Judging from the error message that you received, I'm guessing that you are targeting a 7Series device.
In 7Series, clocks and clock modifying logic cannot be reconfigured as per UG909 and would be required to be in the static region of the deign.
Let me know if this helps.
Best Regards
Aidan
Please mark the Answer as "Accept as solution" if this answered your question
Give Kudos to a post which you think is helpful and may help other users
nipunnaina
 I wanted to change the line rate of GTX in kintex 7 FPGA using DRP reconfiguration. After lot of search I found 1 RTL file in VHDL for virtex 6 device. Please find the attachment.
As per my understanding xilinx would have already such files for reconfiguration using DRP for different devices.
I am not able to find the appropriate file for my device.
Can I get latest file verilog file for drp control for kintex 7 device?
nipunnaina
any updates for my query?
junnit
have you got some example codes now?I am facing the same question,I want to change the line rate trough DRP too in my Kintex7 device,thanks a lot.
