joe306
MGT Clocks: Do I need More?
Hello, I'm using a big Zynq Ultrascale+ MPSOC that has a lot of MGTH pins. I'm using three pairs tx/rx for three fiber transceivers and the other pins I am going to a expansion header. The spare MGTH pins have no immediate need but we put them to a header for future use Do I need to supply two clocks for each Quad?
Here is my programmable clock generator.
Should I add another clock generator and supply clocks to all the MGT Reference Clocks?
Thank you
Joe
joancab
Advisor
Advisor
Thank you for supposing I think. Feel flattered.
"At this time I don't know what I will do with those MGT pins"
That looks like pure research (what I'm doing when I don't know what I'm doing).
It looks like a dev or multi-purpose board (?). In that case I would have one/ several of these I2C-programmable multi-output clock generators (SiLabs has thousands) so you can have same or different frequencies, even disable the unused ones, etc.
joancab
Advisor
Advisor
Looking good that little beast.
One ref clock for all the MGTs in the quad or two, it depends on how you will use them.
joe306
Hello and thank you for responding to my message. Yes, I was expecting that as answer. At this time I don't know what I will do with those MGT pins. If I make all the clocks the same frequency I could use a fanout buffer but that limits me. I guess I will break down and add in another clock generator device.
What do you think?
Thank you
Joe
joancab
Advisor
Advisor
joe306
Thank you very much.
