Visitor dragonl2000l
MGT "RN" power supply group for a XCKU060-FFVA1517
My question is similar to one posted to this forum in 2016 in the post: "Grounding Unused GTH power group - MGTAVCC, MGTAVTT, and MGTVCCAUX"
Specifically, are the MGT power pins with the suffix "_RN" connected on the XCKU060-FFVA1517?
From the "UltraScale and UltraScale+ Package Device Pinout Files" page, the file for the XCKU060-FFVA1517 lists MGTAVCC, MGTAVTT and MGTVCCAUX power pins with suffixes of:
"_L"
"_RN"
"_RS"
The file I am referring to is here: https://www.xilinx.com/support/packagefiles/usapackages/xcku060ffva1517pkg.txt
And in figure 3-18 (page 190) of UG575, the "_RN" pins are shown in the device diagram along with the "_RS" and "_L" pins.
https://www.xilinx.com/support/documentation/user_guides/ug575-ultrascale-pkg-pinout.pdf#page=190
However, table 1-7 (page 46) of that same document shows no quads are powered by the "RN" power supply group on a XCKU060-FFVA1517.
https://www.xilinx.com/support/documentation/user_guides/ug575-ultrascale-pkg-pinout.pdf#page=46
Similarly, table 5-2 (page 316) of UG576 also shows that no quads connect to "RN" supply group for this device.
https://www.xilinx.com/support/documentation/user_guides/ug576-ultrascale-gth-transceivers.pdf#page=316
Are these pins listed for migration purposes only, or are they actually connected on a XCKU060-FFVA1517?
I'd appreciate any insight on this.
Re: MGT "RN" power supply group for a XCKU060-FFVA1517
Hi @dragonl2000l,
the _RN bank is not connected in xcku060-ffva1517.
You also see the available banks in ug575, page63, figure 1-16.
Hi @dragonl2000l,
Thank you for the confirmation.  It looks like this is just one of a few device-and-package combinations where one of these power supply groups is entirely unused.  It's was just interesting that in the other cases I found this to occur (the Virtex devices in the FSVH2104, FLGA2577 and FSVH2892 packages), the pins of the unused power supply group for the smaller device option were labeled as not connected ("NC") in the pinout files.
Thanks again!
Found a related Xilinx note: AR# 59834. It discusses this same topic with another package in the Kintex family.
