Observer akshay_acharya
MGT refclk given to IBERT
Hello sir/madam,
1. In IBERT if the line rate is 12gbps and the DATA_WIDTH = 40. then how much should be MGT_refclk frequency?
Accoring to my knowledge, line rate = DATA_WIDTH * MGT_refclk. Is it proper ? or can I provide any other Frequency? and how to control the value of N in the QPLL?
2. The link is not setting for 12gbps, but it is working fine for 6gbps. What are the changes need to be done in the RX_CDR?
3. I have taken care of the CTLE and DFE configuration, Sometimes the link is set and it is not stable.
How to attain a proper link between the 2 boards, with high line rates?
4. In IBERT core, RXOUTCLK is there is it recovered clock from the RX_CDR?
Akshay kumar
回复: MGT refclk given to IBERT
hi @akshay_acharya
in IBERT customizing GUI, you can select line rate and data width first.
Then if you click on the refclk, it will show you a drop-down list for all the valid reference clocks.
it can be linerate/40 but it is not limited to this frequency.
You can pick up any one and make sure you can provide the same on the board.
IBERT will take care of the QPLL settings.
if 6Gbps is ok but 12G is unstable, you can try LPM mode.
You can also try changing the remote partner TX amplitude, and emphasis.
Boris
