Near-end PCS loopback
I confirmed 2D-eye from iBERT with near-end "PMA" loopback with internal PRBS pattern, but near-end PCS loopback doens't show any eye opening from iBERT. Is this expected one as iBERT is designed for PMA evaluation?
Hi knam@jariettech.com ,
this is expected. Give the receiver block diagram in the transceiver user guide a look. You will find that nepcs loopback loops the parallel data back. Eye scan happens on the serial data. So it depends on what you have connected to RXP/RXN for what you see in the eye scan.
