OBUFDS_GTE4 on ZCU102
Accepted Solution Solved
Accepted Solution
Hi all,
I want to instantiate an OBUFDS_GTE4 to use the clock output RXRECCLOCKOUT out of a CPRI slave core. This clock will feed the Si5328 jitter cleaner. The utility buffer doesn't offer that option so I tried to create a custom IP but altogether, Vivado doesn't let me plug the output of the OBUFDS_GTE4 to the SFP_REC_CLK pins on ZCU102 (pins R10-R9).
Do I need special constraint or configuration during my custom IP generation? Anyone tried to do this before?
JB
回复: OBUFDS_GTE4 on ZCU102
hi jb.larouche@serma.com
you can connect in this way:
RXOUTCLK --> BUFG_GT --> ODDR --> OBUFDS --> output pins.
RXOUTCLK can be set to RXOUTCLKPMA.
In this way, fabric is used to route the recover clock. Dedicated routing is not used.
Boris
All Replies
OBUFDS_GTE4 must use dedicated pinout. just like IBUFD_GTE4.
The dedicated GT reference clock inputs can be configured to input mode (IBUFD_GTE4) or output mode (OBUFDS_GTE4)
Boris
Thanks for your quick reply! Indeed I seem to have access to the dedicated pins. Sadly, on the ZCU102, the SFP ports are on bank 230, so I can't output the RXRECCLK on any SMA connector (I would like to probe the clock), since they are in other clock regions (I get DRC violations).  So basically; on the ZCU102, I can't use RXRECCLK for my ref clock, I need to use the RECCLK output (which can be routed with a simple OBUFDS). Am I understanding this correctly?
JB
Boris
Perfect. Thank you sir.
