ptomaz
PG182 "Constraining the Core" - option not available?
UltraScale FPGAs Transceivers Wizard v1.7 (PG182 April 4, 2018) LogiCORE IP Product Guide, Chapter 4 - Constraining the Core, implies to be possible to manage GT locations manually, for "advanced use cases", by setting DISABLE_LOC_XDC user
parameter to ‘1’ during IP customization. While I see that parameter listed in the .xci files generated by the Wizard, it doesn't seem to be possible to control that option from the Wizard's GUI. Is this option no longer available on recent versions of Vivado? For reference, I am using Vivado v2018.2, and I am trying to generate an IP customization for GTY-10GBASE-R* preset.
simon
Hi @ptomaz
Please try the steps below:
1. Set the required options in the GUI and click OK
2. Choose "Skip" option in the "Generate output products" pop-up
3. Run the following command in Tcl Console to disable the GT location constraints
set_property -dict [list CONFIG.DISABLE_LOC_XDC {1}] [get_ips <ip_name>]
4. Right click on the IP and select generate output products
Simon
simon
Hi @ptomaz
Simon
ptomaz
Thank you, simon!
